Recomendations of Radiators? OEM = $$$!!!!
Old Jan 12, 2004 | 09:15 AM
IloveNewt's Avatar
Default Recomendations of Radiators? OEM = $$$!!!!
I looked at teh oem rad price and its liek 300-400 bucks!!!!
I need an aftermarket rad that is cheaper but around the same size as an aftermarket one. I cant have a rad that is too thick because it will hit my turbo manifold. Any recomendations please....
Thanks.
Old Jan 12, 2004 | 09:24 AM
Jagan'92's Avatar
Default Re: Recomendations of Radiators? OEM = $$$!!!! (MordecaiPSI)
Is the OEM radiator too thick? If not, then radiatorexpress.com and teamradiator.com offer replacements for the stock one, and they're only 120$ or so.
Old Jan 12, 2004 | 09:30 AM
IloveNewt's Avatar
Default Re: Recomendations of Radiators? OEM = $$$!!!! (Jagan'92)
Is the rads from rad express oem?
I need a rad that is around same thickness as stock oem rad.
Old Jan 12, 2004 | 09:42 AM
Jagan'92's Avatar
Yeah it's the same as OEM - plastic top and aluminum, same thickness. Fits the brackets and fans and all, and comes universal like, with the AT hookups for the tranny cooler.
Old Jan 12, 2004 | 10:12 AM
IloveNewt's Avatar
Well i finally found the crack in my radiator. Need to find a new one now....yeaaaa.
I think i will go aftermarket. Which is the best for a direct fit withas little modification needed. Keep in mind i still have my AC condensor. Im also willing to get new slimmer fans if need be. Thanks.
Modified by MordecaiPSI at 7:27 PM 1/12/2004
Old Jan 12, 2004 | 10:43 AM
IloveNewt's Avatar
Default Re: Recomendations of Radiators? OEM = $$$!!!! (jz)
Hmm ok let me update. Ive decided to go with aftermarket rad and aftermarket slim fans.
Which ones cool efficently and which are the slimest? Any recomendations of where to get these products? Thanks.
Old Jan 12, 2004 | 11:37 AM
prelittlelude's Avatar
ok i think that C&R? makes a good after market rad that fits our cars and is around 400 -500. and as far as thin fans go, i think there are 2 that come to mind, and i could be TOTALLY wrong because its been a while since i have looked into this stuff. but check out SPAL and FLexaLite. i think thats what its called
Old Jan 12, 2004 | 11:42 AM
PrecisionH23a's Avatar
If you get a replacement OEM, get a dual core with metal tanks. The plastic ones suck in my opinion.... especially when you are running a turbo car.
You can always get a Modine for like $120, if you need a contact number I can give you my buddies number. He will have to ship it to you from SC though.
On my old set-up I use a fluidyne radiator out of a gsr that I made little support brackets for the bottom and weld them on. I use the same radiator now, but I chopped up my radiator support to hell due to turbo clearance issues.
I would run the C&R with dual slim fit universal fans that summit.com sells.
Old Jan 12, 2004 | 12:06 PM
@ries's Avatar
Default Re: Recomendations of Radiators? OEM = $$$!!!! (GudeH23a)
C&R Mine came with one slim-fan... but I'm probably going to add a second fan. I like the end-tanks on the C&R. Seem to be better quality than other aluminum radiators.
Old Jan 12, 2004 | 12:22 PM
DISMANTLERGSR's Avatar
Default Re: Recomendations of Radiators? OEM = $$$!!!! (emoBB1)
i got a used 94 prelude radiator that i used for a year. ill sell it for $100 bucks
Old Jan 12, 2004 | 01:24 PM
IloveNewt's Avatar
which modelk c&r did u get? Is it for a 4th or 5th gen and are they interchangable as in can u put 5th gen made rads into 4th gen ones with minimal issues?
Where did u get ur c&r?
Old Jan 12, 2004 | 01:34 PM
@ries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MordecaiPSI &raquo;</TD></TR><TR><TD CLASS="quote">which modelk c&r did u get? Is it for a 4th or 5th gen and are they interchangable as in can u put 5th gen made rads into 4th gen ones with minimal issues?
Where did u get ur c&r?</TD></TR></TABLE>
I got it from Dynamic Autosports (949)457-1234. It's for the 4th gen. I believe 5th gen. radiators have different mounting brackets.
Old Jan 12, 2004 | 01:55 PM
SKDRCR's Avatar
i believe koyo makes one but i think they might have plastic end tanks
i would probably go with a gsr fluidyne rad and then make some brackets
danny98r
Jun 20, 2009 01:12 PM
gohonda
Jun 5, 2009 06:23 AM
gsrhb7
Northwest (Sales)
11
May 14, 2007 10:15 AM
Dc2 Powered
Mar 27, 2005 06:27 PM
LudeBoyLeRoy
Jun 16, 2004 04:03 PM
