wich tachomter is correct??
Old Jan 12, 2004 | 07:53 AM
SleepnCiViC's Avatar
Default wich tachomter is correct??
ok guys i wired up my autometer tach to my c5 motor b/c i didnt quite trust my civic cluster, but anyway they read different rpms once i rev above 4500. The factory tach read vtec hittin in about 5900 and the autometer read vtec kickin in about 5600. Which one is more correct. i also hear it make differetn where you get your signal from for the aftermarket tach, certain spots are more accurate.
Old Jan 12, 2004 | 08:16 AM
Ricey McRicerton's Avatar
Default Re: wich tachomter is correct?? (SleepnCiViC)
Aftermarket tach is more correct. I know my stock tach is off 250 or so rpm.
Old Jan 12, 2004 | 08:21 AM
JDM-97CX's Avatar
Default Re: wich tachomter is correct?? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Aftermarket tach is more correct. I know my stock tach is off 250 or so rpm.</TD></TR></TABLE>
Yup my autometer reads about 300 off from my stock one(while the sock one still worked, )
Old Jan 12, 2004 | 10:13 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: wich tachomter is correct?? (JDM-97CX)
sounds like the same problem i had. just installed a new tach in my cx and the old autogage tach said vtec at 5900 and idle at 750. now, the new sport comp says vtec at 5700 and idle at 900.
Old Jan 12, 2004 | 10:15 AM
CleenSi
Guest
Posts: n/a
Old Jan 12, 2004 | 01:38 PM
so c5 vtec kicks in at 5600??
Old Jan 12, 2004 | 01:42 PM
JDMH22HATCH's Avatar
Default Re: (SleepnCiViC)
****, my stock tach is way off especially at high RPM's. I've got the Apexi tach and its accurate as a ****.
Old Jan 12, 2004 | 02:34 PM
mysi92's Avatar
wire your tach off of the wires @ the distributor for best accuracy
Old Jan 12, 2004 | 02:41 PM
uranazo's Avatar
my stock tach is perfectly accurate as far as i can tell, vtec kicks in at exactly 5500 and fuel cut off just a lil past the 7,000 mark (approx 7200 i believe, D16Y8) so but ive never wired up a aftermarket tach, maybe it has some kind of disturbance to the stock tach?
Old Jan 13, 2004 | 12:19 AM
CleenSi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">so c5 vtec kicks in at 5600??</TD></TR></TABLE>
get a timing gun like SNAP-ON or something and check it out that way to see which one is more accurate
because the timing gun is 100% accurate
Old Jan 13, 2004 | 12:25 AM
Filliam H. Muffman's Avatar
Default Re: (CleenSi)
STFU NOOBIE
uh yeah....what everyone else says.
Old Jan 13, 2004 | 04:54 AM
Good ol' Screwtape's Avatar
Multi-paradigm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">
Yup my autometer reads about 300 off from my stock one(while the sock one still worked, )</TD></TR></TABLE>
Really? Deng...I thought the werd was that those were pretty accurate.
Old Jan 16, 2004 | 03:02 PM
CleenSi
Guest
Posts: n/a
Default Re: (JUN EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 &raquo;</TD></TR><TR><TD CLASS="quote">STFU NOOBIE
uh yeah....what everyone else says.</TD></TR></TABLE>
haha derek you bastard....there you go with the noobie **** again.
and who has the faster car??...lol jk ...derek whens the swap coming
Old Jan 16, 2004 | 03:17 PM
madman604's Avatar
honda tachs are usually slower (inaccurate)
Old Jan 16, 2004 | 05:46 PM
King Tut33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleenSi &raquo;</TD></TR><TR><TD CLASS="quote">
because the timing gun is 100% accurate</TD></TR></TABLE>
How is a timing gun going to help him tell if his tach is accurate? All that is used for is to set the base timing for the car which should be 16 degrees BTDC.
96hatchBoy
Jun 8, 2013 02:31 PM
JuggerNuts
Jun 18, 2006 07:35 PM
G2integra217
Jun 12, 2005 11:13 AM
Beezle
Nov 2, 2004 10:33 AM
pikappaphi
Jan 6, 2004 07:41 PM
