High CR pistons in DC2 ITR for S2st2
Old Jan 12, 2004 | 12:49 AM
itr_18's Avatar
Default High CR pistons in DC2 ITR for S2st2
Hi,
Im buying Skunk2 Stage2 cams now. I would like to make higher CR in my B18C6 (11.1 stock). Toda pistons are nice but costs 800$. Wiseco is known also as manufacturer of pistons and its much cheaper. I've found 3 Wiseco high CR pistons:
Bore Over size Comp. ratio
81 std. 11.8-12.25
81.5 .020
82 .040
Can someone tell me what is CR in 81.5 and 82 bore? What about this over size? Do I need to do something more with the block when I put 81.5 or 82 ?
I DONT WANT TO DO ANYTHING TO MY BLOCK (Not in my country ) SO I NEED HIGH CR AND NO sleeving or boring (dont know what) in my block. HELP
Any other good high CR pistons?
Old Jan 12, 2004 | 04:03 AM
paulITR's Avatar
Default Re: High CR pistons in DC2 ITR for S2st2 (itr_18)
With the larger bore you'll MUST bore and hone cilinder sleevs and, with the same piston, compression will be higher due the larger bore about:
81.5 - 0,1 point more then 81.00
82.0 - 0,2 point more then 81.00
The larger bore you can go on stock sleevs is 82.00 mm., but i recommend you to use CTR 81.25 oversize pistons to have like stock reliability with 12.4:1 compression.
You might also use CTR pistons in 81.00 bore and only hone the sleevs, but isn't the best solution to have good rings seals.
You'll be better to use a programmable ecu (Hondata- AEM- Motec) to tune the Stage2 cams because i don't believe that VAFC will do the right job.
Good luck.
P.S. I'm going to build your exact setup here in Europe.
Old Jan 12, 2004 | 06:09 AM
itr_18's Avatar
Default Re: High CR pistons in DC2 ITR for S2st2 (paulITR)
So on 81 pistons will make about 12.0:1 CR? What do you recomend - CTR pistons or Wiseco?
yeah, Ill try to make it working on unichip maybe.
Old Jan 12, 2004 | 06:19 AM
woodog's Avatar
they both will work fine with the cams you chose.
just comes down to how much money you're willing to spend.
Old Jan 12, 2004 | 10:01 AM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_18 &raquo;</TD></TR><TR><TD CLASS="quote">I DONT WANT TO DO ANYTHING TO MY BLOCK (Not in my country ) SO I NEED HIGH CR AND NO sleeving or boring (dont know what) in my block. HELP
Any other good high CR pistons?</TD></TR></TABLE>
Then you CANNOT use forged pistons.
Your ONLY choice is to use stock bore CTR pistons.
Old Jan 12, 2004 | 11:47 AM
b18c-rDC2's Avatar
Default Re: High CR pistons in DC2 ITR for S2st2 (sgT)
i had ctr pistons and skunk2 stage 2 cams in my itr motor, made 203whp with just vafc (no hondata)
jerrys7583
Jun 15, 2012 08:00 PM
kingofbattle909
May 3, 2011 07:33 AM
HmgLauj69
May 24, 2009 02:28 PM
TurboT
Nov 28, 2001 01:42 PM
