whats the best way to clean the rubber around ur windsheild?
Old Jan 11, 2004 | 10:08 PM
JdmFront619's Avatar
Default whats the best way to clean the rubber around ur windsheild?
When I primered my car i kinda got the rubber part around the windshield, whats the best way to maake it look clean again? spray it black with some paint?
if you had this problem. What was the best way to make it look new again?
Old Jan 11, 2004 | 10:32 PM
importdude2000's Avatar
foreverblack
Old Jan 11, 2004 | 10:36 PM
timmy8151's Avatar
Default Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">foreverblack</TD></TR></TABLE>
Forever Black is a permanent solution and in fact is a dye. I've used Mother's Back to Black and thought it was a decent product. But my favorite product for trim is Aerospace 303. Its a water base plastic protectant that provides UV protection on plastic.
Old Jan 11, 2004 | 11:31 PM
Default Re: (timmy8151)
where do you buy this stuff at?
Old Jan 12, 2004 | 04:17 AM
RedTegLS's Avatar
Default Re: (JdmFront619)
I would also like to know where you by this foreverblack at.
Old Jan 12, 2004 | 05:15 AM
mugenracer's Avatar
clean off as much of the primer with petrol or some solvent and then get those wipe things that are supposed to replenish wiper blades, they soften and lubricate the rubber to prevent it from hardening and perishing
Old Jan 12, 2004 | 05:21 AM
ragejed's Avatar
Default Re: (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">clean off as much of the primer with petrol or some solvent and then get those wipe things that are supposed to replenish wiper blades, they soften and lubricate the rubber to prevent it from hardening and perishing</TD></TR></TABLE>
I have never seen these wipes...got a name for them?
Old Jan 12, 2004 | 08:48 AM
The_Todd's Avatar
Farts in the shower
Default Re: (ragejed)
You can use alcohol swabs....they will clean that rubber....won't really protect it but I know armor all makes a compound for it, just can't remember what its called. You can also check out http://www.autodetailproducts.com
Old Jan 12, 2004 | 09:11 AM
timmy8151's Avatar
Default Re: (RedTegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">I would also like to know where you by this foreverblack at.</TD></TR></TABLE>
Try here: http://www.premiumautocare.com/foblpr.html
Old Jan 12, 2004 | 11:49 AM
spnbb2
Guest
Posts: n/a
use dishsoap
stillrockin18s
Welding / Fabrication
Nov 3, 2007 02:40 PM
Techno Tonis
Honda S2000
23
Apr 9, 2007 07:07 AM
John M
Dec 23, 2006 12:30 PM
Jonathan_ED3
Jul 20, 2006 09:43 PM
Takumi Fujiwara
Jun 4, 2005 02:35 AM
