EG6 W/ H22 DONE WITH IMPLANT CAN'T START!
Yeah I have a 92 cx with a 94 H22. We got done with all the technical stuff and now we're at the trouble shooting process. When I turn the car on the fan kicks on and will not shut off. All the gauges will turn on and so will the radio. When I go to start it everything pauses and when I let go everything keeps going. I tried a external distributor but my wire harness is made for a internal. I also tried a new starter and that didn't work.
put an extra ground to one of the starter bolts. that will do it also you need to wire an external coil. which goes like this take the small dizzy plug that has a blk/yel wire and a blue wire. leave the blue wire alone....... take the blk/yel wire and slice it. the end coming out of the harness gets connected to blk/yel wire of coil. the other end of that sliced wire which is connected to the plug goes to yel wire of coil. the green wire from the coil goes in to one of the corner wires from the big plug on the dizzy. you find this because the h22 dizzy will have one extra wire then civic integra harness. located in the big plug on the corner very easy to figure out.. i would make a diagram but we-todd-racing is down. will someone help me post it
JoshJosephKeith
Mar 4, 2009 02:51 PM
