IF I have a 92 civic with a B18c in it. Does an intake that was for the D16 still fit in the B18c?
hey so what about the 2000 ls motor, can you take a cold-air from that and put it in the 95 civic sohc motors?
i am planning on putting a b18c in my del sol. could i use a cai for the b18c? or would i have to make a custom one? or would i have to use a short ram? if none of these work, i guess i'll stick with the stock intake.
thanx
thanx
thanx
thanx
the short ram will work, but with the gsr cai, i heard you have to "modify" it to fit. not sure how though. as soon as i install mine, i'll let you know.
u can get a short ram intake for a civic to fit on a B18C1. GSR has the weird intake manifold that sits down lower then other honda intake manifolds.
99-00 si will fit if you get a skunk2 man. Also if you have a stock man try a gsr intake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NinetyThreeHB »</TD></TR><TR><TD CLASS="quote">hey so what about the 2000 ls motor, can you take a cold-air from that and put it in the 95 civic sohc motors?</TD></TR></TABLE>
yes you can
yes you can
like every body else you can. i got a reg short intake for a civic to fit on a h22A
djay86
Mar 20, 2002 08:55 PM
