heat not workin well ?
My heat does not warm up all the way in my car even after 20-30 mintues of running it. It will warm up a little bit for a minute, then it gets cold again. I just replaced the thermostat in it a month ago, I figured that was the problem. Any suggestions? thanks.
I did a coolant flush at the same time with the thermostat (a month ago) since I was in there already. I also changed the upper radiator hose as well when I did the thermo. I have the lower hose in my garage but its been too cold.
Yes my car does reach operating temp after a little bit seems to take a while, but i think that is normal for an older honda? correct if am wrong, my friends R seems to be that way as well. Any other ideas? Thanks.
Her name is Caprice, some model I think...
Well, does anyone else have any ideas??? Its been pretty cold here, I need heat when I go to work at 5:30 in the moring.
after you get ur car up to normal operating temp. Turn the heat on full, rev to red line a few times. If u feel a burst of heat from the heater then you might have low coolant. it happened to me in my legend after I put my rad back in. just a suggestion might want to try it
My coolant is full though I topped it off the other day, its at the top of the radiator cap and full in the tank.
Could my water to coolant ratio matter?
even if u toped if off there could still be air in the system. it might not be over heating because it's so cold outside. just my .02
dbailey
11
Jan 30, 2020 04:27 AM
dlstech
16
Dec 12, 2012 03:04 AM
d16a9_edcivic
13
Dec 14, 2008 11:50 AM
