D series crank shaft
Old Jan 11, 2004 | 03:56 PM
f31roger's Avatar
Default D series crank shaft
does anyone know if there is a difference between D series cranks?
I'm rebuilding an Sohc vtec motor and the crank is bent.
I have a spare DX motor. just wondering if they have the same crank.
I know its stupid question for some tech guys, but help a fellow honda guy.
thanks
Old Jan 11, 2004 | 04:39 PM
dsadas89das78934's Avatar
Default Re: D series crank shaft (driftkaztik)
the cranks are different between D15's and D16's .... but within their respective displacements, the cranks are the same
except for teh D17.... it doesnt fit anything.
Old Jan 12, 2004 | 06:27 PM
f31roger's Avatar
I ask because I got a D16 sohc vtec motor, but the front of the crankshaft is bent (it was dropped) Everything else bout the motor is good, but I also have a DX motor sitting around.
Would it make a huge difference by using a different crank?
Old Jan 12, 2004 | 07:29 PM
builthatch's Avatar
MiG-21 superfan
Default Re: (driftkaztik)
which dx motor? a 1.5 or 1.6? If its a 1.6 (d16y7), it will work. Otherwise it is a nogo.
Old Jan 14, 2004 | 01:44 AM
f31roger's Avatar
dx motor from 92-95, which i believe is not a 1.6.
anyone know how much an aftermarket crank costs for a 1.6 sohc vtec?
Old Jan 14, 2004 | 02:07 AM
ATS*Mark's Avatar
OG triple OG
is there an aftermarket y8 crank??
Old Jan 14, 2004 | 03:17 AM
JDMCRX's Avatar
Default Re: (Hella_JDM)
I do not think so
Old Jan 14, 2004 | 04:17 AM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">is there an aftermarket y8 crank??</TD></TR></TABLE>
Sure, some stroker units too...but there is not need for anything but the stock crank. It is plenty stout for anything you can throw at it.
hondacivic90zc
14
Jun 18, 2007 10:25 PM
DigitalFusion
Jun 14, 2002 04:10 AM
vtec_powah
Apr 2, 2002 10:10 AM
