Glass scratch remover
Old Jan 11, 2004 | 03:44 PM
Kryptonite's Avatar
Default Glass scratch remover
My girlfriend just bought a rather old eg hatch and the owner failed to replaec the wiper blade so there are a few semicircular scratches. Does any body know a good scratch remover for glass? I found a home made recipe to fix it but I am relucctant to try that. Thanx before hand fells!
Old Apr 8, 2005 | 07:45 AM
BuBBa y0!'s Avatar
Default Re: Glass scratch remover (Kryptonite)
bump, somebody's gotta know
Old Apr 8, 2005 | 07:52 AM
F22PwrdS2k's Avatar
i need to know too
Old Apr 8, 2005 | 07:57 AM
ViZ's Avatar
ViZ
Default Re: (H22PwrdHatch)
bump here also.. i know there is a polishing system that has a brush you put on your drill but i dont know the name of the maker
Old Apr 8, 2005 | 08:00 AM
Pworld's Avatar
From: somewhere in INGLEWOOD chillin in tha hood, CA
Default Re: (ViZ)
i heard that a certain grade of brillo pad or something will take out scratches. I forgot what number, but it should say on the box, what its good for. Trick i learned at the shop
Old Apr 8, 2005 | 08:14 AM
Nextelbuddy's Avatar
Default Re: (ViZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViZ &raquo;</TD></TR><TR><TD CLASS="quote">bump here also.. i know there is a polishing system that has a brush you put on your drill but i dont know the name of the maker</TD></TR></TABLE>
just <FONT SIZE="3">FLITZ IT</FONT>
lol
Old Apr 8, 2005 | 08:23 AM
ViZ's Avatar
ViZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">just <FONT SIZE="3">FLITZ IT</FONT>
lol </TD></TR></TABLE>
sorta, this was more of a glass only thing and it was a flat pad like a sanding disc
Old Apr 8, 2005 | 08:26 AM
KiD Fr0m Da 516's Avatar
bump i need to know this also have the same problem, the moron who had my coupe b4 me did the same thing
Old Apr 8, 2005 | 11:35 AM
moacsupreme's Avatar
Default Re: Glass scratch remover (KiD Fr0m Da 516)
Luckily when I bought my car, somebody had placed a brick through the windshield. So, instead of worrying about the scratches. I just got to buy a new windshield for it.
Anyways...I know that eastwood sales a glass polishing kit that is supposed to take out small chips and scratches. There are probably cheaper ways to take out the scratches though.
Old Apr 9, 2005 | 10:36 AM
BuBBa y0!'s Avatar
Default Re: Glass scratch remover (moacsupreme)
updog
Old Apr 11, 2005 | 09:00 AM
F22PwrdS2k's Avatar
bump
Old Apr 11, 2005 | 09:08 AM
fqnjdmboy's Avatar
This sounds retarted but crisco on a portable hand buffer works wonders....Im being serious too....
Old Dec 19, 2005 | 09:16 PM
VTAC-KAT's Avatar
Default Re: (fqnjdmboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fqnjdmboy &raquo;</TD></TR><TR><TD CLASS="quote">This sounds retarted but crisco on a portable hand buffer works wonders....Im being serious too....</TD></TR></TABLE>
Is this true? Can someone confirm this?
Old Sep 24, 2008 | 08:44 PM
vietnamezerice's Avatar
Default Re: (VTAC-KAT)
I'm bringin' this up from the dead
Old Sep 24, 2008 | 08:58 PM
torontoefsedan's Avatar
get a new [freak]ing windshield !!!
Old Sep 24, 2008 | 10:04 PM
DangerMouse's Avatar
Default Re: Glass scratch remover (Crono139)
Clear nail polish?
Old Sep 25, 2008 | 06:03 AM
SneezinCD5's Avatar
Default Re: (torontoefsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torontoefsedan &raquo;</TD></TR><TR><TD CLASS="quote">get a new [freak]ing windshield !!!</TD></TR></TABLE>
Why would you do that when it can be fixed? Its much cheaper repairing it than getting an OEM winshield installed. Most aftermarket ones have defects in them.
Old Sep 25, 2008 | 06:53 AM
racerxh00's Avatar
Default Re: (SneezinCD5)
i know that one of the companies that does the headlight restore kits also sells one for windshields, the company is called crystal view. also i know that at the local plastic shop, plastics 2000, they sell like a polishing/rubbing compound for glass. i have not tried either of these things, so i dont know how it works.
Old Sep 25, 2008 | 06:54 AM
speedaddict's Avatar
old school hot rod guys use toothpaste...yes this is true...toothpaste.
Old Sep 25, 2008 | 08:34 PM
Default Re: (speedaddict)
does any kinda of tooth paste matter?
I don't want to go that route because I want to keep the OEM windshield and plus it would cost more
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 &raquo;</TD></TR><TR><TD CLASS="quote">
Why would you do that when it can be fixed? Its much cheaper repairing it than getting an OEM winshield installed. Most aftermarket ones have defects in them. </TD></TR></TABLE>
that's true... thanks for chiming in man
Old Sep 25, 2008 | 08:42 PM
Crono139's Avatar
Default Re: (vietnamezerice)
Pure white toothpaste, I'd assume.
That's what I've used on CDs in the past.
Old Sep 25, 2008 | 08:52 PM
Turbo Dan's Avatar
toothpaste is/was used because it has a sort of grit to it, combined with a high speed polisher works as a rubbing compound.
alternatively, you could also buy a proper bottle of rubbing compound and use a high speed polisher to do the same or better.
personally i dont know if this will help at all, but its worth a try
i would assume you would need a pretty harsh grit rubbing compound and or several grits of compounds in order to get results.
Old Sep 25, 2008 | 08:53 PM
Default Re: (Turbo Dan)
turbodan is correct...depends on how deep the scratches are as well
Old Sep 26, 2008 | 07:21 AM
it's not bad at all... nothing where it'll catch my finger nail... it just creates a glare during the day or at night causing it difficult to see through... safety first you guys think doing it by hand will help? I don't have a high speed buffer readily available
Old Sep 26, 2008 | 01:23 PM
sicc83's Avatar
If you use compound and a buffer make sure to keep it very wet with water otherwise it will overheat and crack.
