Jl w7 13.5 w/ custom plexi Glass box...
Old Jan 11, 2004 | 11:09 AM
Matgallis's Avatar
Default Jl w7 13.5 w/ custom plexi Glass box...
PENDING SALE
PICTURES AT BOTTOM
$700 obo!
I had this box built last May. Two months later my car died and the system has just been sitting around. I spent $900 on the w7 13.5 and another $700 on the custom box. The sub still works 100%
The specs for the w7
Dimensions:
Frame Diameter: 14 in. (356 mm)
Mounting Hole Diameter: 11.9 in. (302 mm)
Mounting Depth: 10.5 in. (267 mm)
Overall Depth: 12 in. (305 mm)
Magnet Diameter: 8.38 in. (213 mm)
Pole Vent Clearance: 0.75 in. (19 mm)
Displacement: 0.21 cu. ft. (4.5 ltrs)
Enclosure Recommendations:
Sealed Range: 1.5 - 2.25 cu. ft. (42.48 - 63.72 ltrs)
Recommended Sealed Volume: 1.875 cu. ft. (53.1 ltrs)
Fc: 40.8 Hz
F3: 36.3 Hz
Qtc: 0.806
Ported Range: 2.0 - 2.75 cu. ft. (56.6 - 77.9 ltrs.)
Recommended Ported Volume: 2.375 cu. ft. (67.3 ltrs)
Recommended Tuning: 30 Hz
This sub can handle a huge amount of power.
More spec at http://www.jlaudio.com/subwoofers/13W7.html
Now the pictures..
The front of the box is 3/4" Plexiglass. The inside of the box is sprayed with a two color spackle type paint. The front design is NOT permanent.
The box was well built with 3/4" MDF wood. Everything in the box is re enforced to handle the bass.
The sub fires into the car (reduces rattle in the trunk)
I'm asking for $700 OBO.... Shipping prices will vary but I won't over charge (I'll cover some of the costs...)
The Amp Is also for sale at $189 OBO I had it rebuilt last April (old installion error fried the board) had the board replaced by MTX for $90 Sold
Modified by Matgallis at 11:58 PM 1/21/2004
Modified by Matgallis at 4:10 PM 2/2/2004
Modified by Matgallis at 6:07 PM 3/14/2004
Modified by Matgallis at 11:30 PM 4/7/2004
Modified by Matgallis at 1:36 AM 4/8/2004
Modified by Matgallis at 8:03 PM 4/13/2004
Modified by Matgallis at 8:21 PM 4/22/2004
Modified by Matgallis at 7:09 PM 8/16/2004
Old Jan 11, 2004 | 04:35 PM
Matgallis's Avatar
Default Re: Jl w7 13.5 w/ custom plexi Glass box... (98 Prelude)
the amp is a mtx 81000d
Old Jan 12, 2004 | 10:33 PM
config's Avatar
bump.. cus if i had the money id buy it
Old Jan 13, 2004 | 12:45 AM
VtecBio009's Avatar
bump for an awesome sub
Old Jan 14, 2004 | 02:28 PM
Matgallis's Avatar
Default Re: Jl w7 13.5 w/ custom plexi Glass box... (VtecBio009)
You won't be disappointed with this sub/setup
Old Jan 16, 2004 | 06:40 PM
superthug's Avatar
Default Re: Jl w7 13.5 w/ custom plexi Glass box... (Matgallis)
you got PM
Old Jan 21, 2004 | 03:00 PM
Matgallis's Avatar
Default Re: Jl w7 13.5 w/ custom plexi Glass box... (superthug)
ttt
Old Jan 23, 2004 | 11:44 PM
Matgallis's Avatar
bump
Old Feb 1, 2004 | 06:47 PM
Matgallis's Avatar
Just measurd the box
35.5" Length
13" Width (needs at least 2 inches by the sub)
16" tall
EDIT: Death to my host
Modified by Matgallis at 2:42 AM 4/8/2004
Old Feb 2, 2004 | 12:47 PM
Matgallis's Avatar
BUmp for new price
Old Feb 3, 2004 | 05:03 PM
Matgallis's Avatar
bump for going on e-bay tonight...
Old Feb 6, 2004 | 01:05 PM
VtecBio009's Avatar
whats your reserve set at on Ebay?
i might buy it from you out of Ebay if possible and if you're price is reasonable.
Old Feb 6, 2004 | 02:19 PM
ill45's Avatar
bump for JL
Old Feb 13, 2004 | 03:02 PM
Matgallis's Avatar
Default Re: Jl w7 13.5 w/ custom plexi Glass box... (ill45)
Now on e-bay
http://cgi.ebay.com/ws/eBayISA...00769
Old Mar 14, 2004 | 09:07 AM
Matgallis's Avatar
lowered price $800
Old Mar 23, 2004 | 07:23 AM
Matgallis's Avatar
ttt
Old Apr 7, 2004 | 02:30 PM
Matgallis's Avatar
New Pictures BUMP
Old Apr 7, 2004 | 03:43 PM
Matgallis's Avatar
ttt
Old Apr 7, 2004 | 04:36 PM
Matgallis's Avatar
Even lower price.... $750
Old Apr 7, 2004 | 07:55 PM
Matgallis's Avatar
night bump
Old Apr 8, 2004 | 08:27 AM
Matgallis's Avatar
Morning bump
Old Apr 8, 2004 | 08:34 AM
lDanny's Avatar
where are you located?
Old Apr 8, 2004 | 09:20 AM
Matgallis's Avatar
Default Re: Jl w7 13.5 w/ custom plexi Glass box... (DuMa)
Northern california
Old Apr 8, 2004 | 10:34 PM
Matgallis's Avatar
getting off at 11:30pm bump
Old Apr 10, 2004 | 01:47 AM
Matgallis's Avatar
bump
