Oil filter size?
Old Jan 10, 2004 | 09:09 PM
98cwitr's Avatar
Default Oil Filter Size?
i went to the stealership last week and picked up and oil filter. I changed my oil today and noticed that the oil filter that they gave me was a lot smaller than the normal oil filters i have been using. Is this a good or bad thing?
Old Jan 10, 2004 | 09:37 PM
sgT's Avatar
sgT
Default Re: Oil Filter Size? (98cwitr)
Good or bad? not good, not bad.
The smaller filter seems to become a restriction in the oiling system.
For normal usage this is fine. For racing however....
i prefer to use the larger size, but from what i hear they are trying to only sell
the smaller one from now on. Time to go to non honda i guess.
Old Jan 10, 2004 | 09:51 PM
98cwitr's Avatar
Default Re: Oil Filter Size? (sgT)
just .02 but using a RSX oil filter would reduce the restriction (even from what im used to using)...but wouldnt it lower oil press.?
Old Jan 11, 2004 | 09:10 AM
sgT's Avatar
sgT
it raises pressure, which means that it is a restriction.
Old Jan 11, 2004 | 09:19 AM
sil's Avatar
sil
if you want OEM.. you can move to the s2000 oil filter.. which is the same size as the previous 'larger' filters, and has been examined to be identical to the HAMP filters made by toyo-roki.. if you can get it for a reasonable price that is.. i know that manhonda.com now sells a case of 10 for 55..
Old Jan 11, 2004 | 02:23 PM
Mr.Fairlady's Avatar
Well,.I'm looking to get some Filters as well!
do most normally use OEM Acura filters?
Whats up w/ the HAMP ones,..and people using DC5 ones?
Which ones should i buy if the previous owner on my ITR used all OEM parts,..as long as I use the same Oil I'm coo right?
Please fill me in on what to start using! SEARCh is fucked!
Old Jan 11, 2004 | 05:04 PM
ejprimo's Avatar
Default Re: Oil Filter Size? (Mr.Fairlady)
the s2000 oil filter ,15400-PCX-004, is the same size as the older discontinued filters.
Old Jan 11, 2004 | 05:05 PM
mickey513's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwitr &raquo;</TD></TR><TR><TD CLASS="quote">i went to the stealership last week and picked up and oil filter. I changed my oil today and noticed that the oil filter that they gave me was a lot smaller than the normal oil filters i have been using. Is this a good or bad thing?</TD></TR></TABLE>
It is normal. Honda has gone to a smaller filter on all 4 cylinder cars. It suppose to give better oil pressure for the vtec. I suspect they copied Toyota's design because the 00-04 Celica also used a tiny oil filter inorder to get enough oil pressure for the VVTL-I.
Old Jan 11, 2004 | 11:51 PM
sgT's Avatar
sgT
Default Re: Oil Filter Size? (mickey513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mickey513 &raquo;</TD></TR><TR><TD CLASS="quote">
It is normal. Honda has gone to a smaller filter on all 4 cylinder cars. It suppose to give better oil pressure for the vtec. I suspect they copied Toyota's design because the 00-04 Celica also used a tiny oil filter inorder to get enough oil pressure for the VVTL-I.</TD></TR></TABLE>
Most people are checking oil pressure before the filter.
If pressure goes up there, what does that tell you about how much is going to the head?
I would like to see pressure readings before/after taken at the head.
Old Jan 12, 2004 | 11:59 AM
sil's Avatar
sil
also keep in mind that honda is spec'ing 5w20 oil now.
Old Jan 12, 2004 | 10:48 PM
RGoose18's Avatar
Default Re: Oil Filter Size? (sil)
Unless your car sees heavy track usage, who cares, it's just a filter. The "new" OEM is fine
Old Jan 12, 2004 | 11:20 PM
DC5ITR329's Avatar
Default Re: Oil Filter Size? (RGoose18)
I'm using the new thinner filter for my rsx. I also have the new hamp filter and it's currently in my car. IMO it runs better.
nicholasellin
Honda Civic (2001 - 2005)
May 6, 2014 09:52 AM
alexthegrinch
Nov 16, 2009 03:14 PM
frankie11
Sep 2, 2007 01:54 PM
silentdeath12886
Dec 18, 2006 04:04 PM
kabob
Aug 23, 2002 12:37 PM
