clicking/clapping noise
Old Jan 10, 2004 | 03:39 PM
972drcordex's Avatar
Default clicking/clapping noise
Good news I got my sport lines installed. But i was driving it home and the right rear has this like clunking noise if i go over a ridge or bump. Can i correct this myself and if so just let me know.Thanks
Old Jan 10, 2004 | 07:23 PM
jwogen1's Avatar
Default Re: clicking/clapping noise (972drcordex)
that is crazy man, because i had the same thing 3 years ago when i had my sportlines installed on my 94 accord. when i would exit a driveway type into the road or hit a bump of some sort i heard the clunk sound. it sounded as if something fell off or was loose. i replaced the upper a-arms(oem), the rear struts(oem) and i still continually put white lithium grease on all the bushings in the area(both sides of the car for this stuff). now i will say it doesnt seem as bad, but the noise has subsided. my mechanic friend and i never really pinpointed the exact problem, so i assumed they were settling or just some new stresses on the stock suspension components. i am getting ready to install some new kyb struts which cant hurt. this doesn't help much, but i havent had any problems. the car sits just fine and level, i have autox a few times and everything is fine.
Old Jan 10, 2004 | 07:28 PM
jwogen1's Avatar
also it will probably be a month or two before i install the new KYBs, but i can IM you and let you know if there are any changes...and keep me posted if you have any more problems or it gets better over time. i havent heard anyone else with this issue, and i will say that i try to take the bumps etc slower just to be nice to her!
Old Jan 10, 2004 | 07:55 PM
p0pe's Avatar
I installed mine over a year ago and still have this noise occasionally.I think it's just because the rear springs are progressive and the coils that are close together slap against each other.
Old Jan 10, 2004 | 08:09 PM
jwogen1's Avatar
Default Re: clicking/clapping noise (p0pe)
do you have the noise coming from both sides?
Old Jan 10, 2004 | 08:10 PM
jwogen1's Avatar
Default Re: clicking/clapping noise (jwogen1)
makes sense i guess, but it doesnt exactly sound good
Old Jan 10, 2004 | 09:37 PM
well, my friend and i just tightened the top bolt on the strut in the trunk. That helped but the noise is still there now and then. Im gonna see if the spring didnt get snapped all the way into place.
Old Jan 11, 2004 | 07:45 AM
jwogen1's Avatar
let me know if it helps, cause when i put the new KYBs on, i am going to recheck everything.
Old Jan 11, 2004 | 06:51 PM
brads94accord's Avatar
i had that same problem when i first installed my sprint springs on my 5th gen. everytime i would start off at a light or put it in reverse or drive it would do it. it didn't go away until i replaced my factory shocks with aftermarket ones. i believe it was caused by stress on the shocks.
Old Jan 11, 2004 | 08:39 PM
jwogen1's Avatar
Default Re: (brads94accord)
yeah im hoping the new KYBs will cure all
Old Jan 11, 2004 | 08:47 PM
twkdCD595's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p0pe &raquo;</TD></TR><TR><TD CLASS="quote">I think it's just because the rear springs are progressive and the coils that are close together slap against each other.</TD></TR></TABLE>
you hit the nail on the head here... my spring coils at top and bottom sit on each other. this creates an occational rebounding clap when I hit a rough road.
sohcFerio
Suspension & Brakes
11
Dec 10, 2011 02:50 AM
Civic2000EX
Suspension & Brakes
Jul 4, 2007 02:09 PM
xmr. robotox
Suspension & Brakes
Apr 30, 2006 12:44 PM
Layziebtnh055
May 3, 2004 12:52 PM
distortedfuture
26
Feb 4, 2004 12:13 AM
