Oil change after storing?
Old Jan 10, 2004 | 03:14 PM
daddymaxx's Avatar
Default Oil change after storing?
ok here's the deal. I changed my oil (mobil 1) about 500 miles before storing it. I start the car every couple weeks and let it run for 15-20 minutes.
Now I know syntehtic oil doesn't go bad, so should I still change it when spring comes? Or can I drive another couple thousand miles before changing?
Old Jan 10, 2004 | 03:47 PM
HXMan's Avatar
Default Re: Oil change after storing? (daddymaxx)
I would change it...all the condensation and stuff that accumulates in the block in storage is going to eventually fall to the oil pan and get in your oil.
Old Jan 10, 2004 | 06:14 PM
itr 00 0108's Avatar
Default Re: Oil change after storing? (HXMan)
Yep, change it...my car has been in storage for 2 months with 2 months to go...
And I wouldn't be starting it like you are....that's a pretty dry start so you are hurting more than you're helping.
Old Jan 10, 2004 | 06:16 PM
daddymaxx's Avatar
I heard I should be starting my car weekly to keep the juices flowing. And I'm supposed to move the car around a bit to keep my tires from getting flat spots.
Old Jan 10, 2004 | 06:19 PM
Default Re: (daddymaxx)
Well hey man, it's up to you....I'm sure as hell not gonna put my engine through that. Think of what's happening...all your fluids (oil included) is draining down...no oil where it should be, means dry starts....
As far as the flat spot thing goes....keep your tires properly inflated and they will be fine.
Old Jan 10, 2004 | 06:20 PM
daddymaxx's Avatar
hmmm tha'ts werid.... I remeber hearing that sarting is the thing to do.... anybody else have any input?
Old Jan 11, 2004 | 10:42 AM
Holding monSteR's Avatar
i start mine every 2 weeks to a month. I'm not sure what the alternative would be. Hell, if you let your car sit for 3-4 days in the summer you're definately gonna have the same thing (dry start). If you're close to the car i'd start it every week, but other than that i can't think of anything better. And yeah i also move the car when i start it to prevent flat spots, it's a good idea.
Old Jan 11, 2004 | 10:53 AM
Todd00's Avatar
I said I don't want a title!
Default Re: (CanadianR)
Flat Spots? Those will go away within the first 5 minutes of driving.
Also, putting a load on the motor and driving is different than just starting it up every now and then. Just let the car sit all winter--it won't hurt it.
There has been 267579 threads about this. Do a search.
Old Jan 11, 2004 | 11:20 AM
seek167's Avatar
Default Re: (Todd00)
go to sears and get 4 jack stand for lik 40 bucks and no need to worry about flat spots or dry rot
Old Jan 11, 2004 | 12:55 PM
Mugen Mike's Avatar
I would change the oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddymaxx &raquo;</TD></TR><TR><TD CLASS="quote">And I'm supposed to move the car around a bit to keep my tires from getting flat spots. </TD></TR></TABLE>
Over-inflate them by about 5 psi and they'll be fine
9integra2
Feb 12, 2009 06:33 PM
07FG2
Honda Civic (2006 - 2015)
41
Feb 9, 2009 05:58 PM
yobtah
Feb 24, 2003 11:12 AM
io_burn
Dec 30, 2002 05:01 PM
EF8_SiR
Oct 3, 2002 02:14 PM
