My turbo R (Pics) 56k go away
Old Jan 10, 2004 | 02:05 PM
FOrSfEd's Avatar
Default My turbo R (Pics) 56k go away
Sorry about the engine being dirty I just finished.
Old Jan 10, 2004 | 02:08 PM
Too_Smooth's Avatar
I guess you got the return line straight huh? Well bout time you got that thing running.
Old Jan 10, 2004 | 02:30 PM
E-Rok's Avatar
EPIC TUNING
Default Re: (Too_Smooth)
is that the stock radiator? it looks nothing like the one in my teg.
Old Jan 10, 2004 | 02:38 PM
Shaun's Avatar
Default Re: (rewsnaeht)
nice work man
Old Jan 10, 2004 | 02:48 PM
ITR9788's Avatar
Default Re: (Shaun)
I beleive you were the one who was going to run the sidewinder. If so, what made you change your mind to run that one?
Old Jan 10, 2004 | 07:03 PM
FOrSfEd's Avatar
Default Re: (ITR9788)
Yeah I am the one that was going to. I actually did run it for a while, and it was fine but kinda hard to work under the hood with everything fitting so tight and the heat under the hood was crazy. I really like that manifold and it made my turbo spool like 2500 faster than the new one but I got a damn good deal on this from Danny so I could not pass this up.
Old Jan 10, 2004 | 07:39 PM
Ri5e's Avatar
Default Re: (FOrSfEd)
Looks like you are running regular rubber couplers from Home Depot?? If they are, I wouldn't recommend running that rubber coupler on the compressor outlet because it'll eventually burst/rip
Always use nitrile rubber or silicone on the outlet
Old Jan 10, 2004 | 07:47 PM
ueatdooki's Avatar
Default Re: (BG Boost)
wheres the fmic?
Old Jan 10, 2004 | 07:52 PM
psi420's Avatar
Nice filter you got on that turbo.
Old Jan 10, 2004 | 07:53 PM
FOrSfEd's Avatar
Nah I'm using the hard rubber ones from napa.
There is a front mount there in that picture just have it hidden pretty good.
Old Jan 10, 2004 | 07:54 PM
FOrSfEd's Avatar
It's a dual core radiator from and integra not sure which year though.
Old Jan 10, 2004 | 07:55 PM
FOrSfEd's Avatar
Default Re: (psi420)
Took these pics before I out the filter on
Old Jan 10, 2004 | 08:04 PM
fast[R]'s Avatar
Looks almost like mine
Old Jan 10, 2004 | 08:06 PM
FOrSfEd's Avatar
Default Re: (fast[R])
Your looks better since you can see the intercooler wish had a nicer intercooler but I guess it will do for now, and you have your lip . U mine posting any pics you might have. I can only see the one from your avatar.
Old Jan 10, 2004 | 09:46 PM
ITR9788's Avatar
How bad were the under the hood temps?
Old Jan 10, 2004 | 10:05 PM
racinskittle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">Nice filter you got on that turbo. </TD></TR></TABLE>
Yeah, it's sometimes difficult to fit the filter in there.
How'd you do it?
Nice car BTW.
Old Jan 10, 2004 | 10:58 PM
FOrSfEd's Avatar
Nothing that a new slim line fan wont fix, and when I did have it I should have wrapped the manifold and the dp would have helped me out alot but I was just to lazy to do it.
Old Jan 10, 2004 | 11:12 PM
thermal's Avatar
nice man! .....oooooo, I cant wait to get mine installed!
Old Jan 11, 2004 | 07:19 AM
ITR9788's Avatar
Default Re: (thermalfi'd16)
I plan on running a Sidewinder but am still worried about theunder hood temp problems. I would probably have it jetcoated, but cant stand the look of heat wrap. I have to have a little bling. The mani looks so damn cool, and the heat wrap would ruin that.
Old Jan 11, 2004 | 07:21 AM
FOrSfEd's Avatar
The one I sold was jet coated but it still didn't really help with the high heat. The black heat wrap looks pretty coo in my opionion.
Old Jan 11, 2004 | 08:52 AM
RobbieG35's Avatar
12 Years Strong
That looks really good. What kind of numbers you lookin for?
Old Jan 11, 2004 | 09:01 AM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BG Boost &raquo;</TD></TR><TR><TD CLASS="quote">Looks like you are running regular rubber couplers from Home Depot?? If they are, I wouldn't recommend running that rubber coupler on the compressor outlet because it'll eventually burst/rip
Always use nitrile rubber or silicone on the outlet </TD></TR></TABLE>
I agree because once those cheap-*** couplings heat up they will pop off in a heart beat. DO NOT GET "HOSE TECHNIQUES" COULPLINGS either...They suck!!!! I wasted $65 on mine and they blowed off everytime i boosted (9psi). You can actually get some really good "industrial grade" silicone couplings from supply houses in your area. They are about $1.25/in (length wise) & up depending on the diameter size. I redid all of mine and only ended up paying about $25 for all of the necessary couplings for my setup. Trust me, you don't want to be reclamping a coupling in the middle of traffic with a hot *** engine bay to deal with too.
Old Jan 11, 2004 | 09:03 AM
ITR9788's Avatar
Default Re: (NVturbo)
Where have you seen this cool looking black heat wrap?
Old Jan 11, 2004 | 09:22 AM
FOrSfEd's Avatar
Summt sells it. I'll see if I can find it.
Old Jan 11, 2004 | 10:04 AM
95LSDOHC's Avatar
Default Re: (ueatdooki)
nice job hiding the IC man...setup looks good
