Not honda relate, but dope none the less (boost OwnZ), (56k maybe).
Check out what we did this weekend.
1JZ no ****!!!
The owner of the beast with the ghetto JDM pose.
Motor going in, along with the transmission
Getting ready to roll out
Motherf*cking WARD!!!
Specs as of right now: Bought a 93 Toyota Soarer front clip (1JZ-GTE), 6 puck clutch, and thats it right now. I'll post impressions of the first ride later. Thats all for now.
Modified by sydag5 at 6:11 PM 1/10/2004
1JZ no ****!!!
i was planning on doing that swap over the summer. what all was needed to be done to the engine harness and what ecu are u running the jdm or ?? id love to see the whole write up on what all u did to make it work...u can email me the info also. bad *** work tho and it looks great
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslow94 »</TD></TR><TR><TD CLASS="quote">i was planning on doing that swap over the summer. what all was needed to be done to the engine harness and what ecu are u running the jdm or ?? id love to see the whole write up on what all u did to make it work...u can email me the info also. bad *** work tho and it looks great
Well If you are going to do the swap, buy the front clip. It will make life so much easier. We used the 1JZ harness that came with the clip and his stock 2JZ-GE transmission. The clip was an automatic and we are running the automatic ECU for now.
Modified by sydag5 at 6:27 PM 1/10/2004
</TD></TR></TABLE>Well If you are going to do the swap, buy the front clip. It will make life so much easier. We used the 1JZ harness that came with the clip and his stock 2JZ-GE transmission. The clip was an automatic and we are running the automatic ECU for now.
the soarer is the toyota version of the sc series lexus here. they usually come with a 4.0 v8 or a 2.5tt i6. the later versions received the 3.0 i6 found in the supra....the infamous 2jzgtte
Sorry about that guys, the motor went into a 93 lexus sc300 5 speed. Just got back from the first ride, let me tell you that bone stock this car is pretty stout. HKS exhaust and downpipe are coming in on monday, so we'll see what its like with that and at 20psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslow94 »</TD></TR><TR><TD CLASS="quote">cool what all did u use to extend the wiring to make it to the right side of the car? thanks</TD></TR></TABLE>
We just used normal 16 gauge wire and extended the harness 2 ft. There was like 90 some odd wires.
SOL Food
Oct 7, 2006 12:04 PM
