infamous honda idle...noooooooooooooooooo!
Old Jan 9, 2004 | 09:33 PM
otakueric's Avatar
Default infamous honda idle...noooooooooooooooooo!
i have a EK and my engine is throwing code 14
my idle is funky, it goes upto 1500 then bounces back to a grand cause i think its like the ecu is governing the idle to 1500...so i wanted to check if this was it so i changed the idle setting to about 3000 rpm, and i was right, it goe supto 3000 at first then it drops to 1500..but weirdly it goes back up to 3000 in a few minutes...
i pulled the tps plug and the idle was fine, none of the pulsing at 1500rpms...but ofcourse cant rev past 3000
the work i did is..
i swapped in a worked itr bottom end, a gsr head, im using the gsr ecu
i also swapped from automatic to manual
man i want to get this done
any help would be awesome... please!
notes that might help:
1. for some reason my heating doesnt work anymore..i cant even move my little temp setting to the right anymore...it just bounces back to about 2/3 to the right
2. when im really on the gas, like gunning it at 6 and 7 grand, and i just drop it in neutral, the car sometimes dies, or just goes down to like 100rpm about to die, sometimes comes back up, sometimes stalls.. but i think thats the fuel pump, my friend has same problem and walboro 255 fixed it up right...
please help!
Old Jan 9, 2004 | 09:49 PM
92civeg's Avatar
Default Re: infamous honda idle...noooooooooooooooooo! (otakueric)
your "funky" idle could be caused by something as simple as air bubbles in your coolant or a dirty iacv...as far as the stalling i would try upgrading your fuel pump
Old Jan 9, 2004 | 09:53 PM
ARIZONA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by otakueric &raquo;</TD></TR><TR><TD CLASS="quote">
You zip tied something doing electronics trying to hide the wires...
Or a wire running inbetween the control lines/levers.... Been there...
Old Jan 9, 2004 | 09:58 PM
92civeg's Avatar
Default Re: infamous honda idle...noooooooooooooooooo! (ARIZONA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARIZONA &raquo;</TD></TR><TR><TD CLASS="quote">
Or a wire running in between the control lines/levers.... Been there... </TD></TR></TABLE>
thats sound like its most likely the cause of that problem
Old Jan 9, 2004 | 10:03 PM
otakueric's Avatar
zipties are mybest friends haha...
now that i think about i had to remove my console to replace my boot, i guess something got lodged there while i was putting the console back...thanks... now for the mor eimportant problem..the idle (:
would a bubble in the coolant cause my engine to throw the code?
Old Jan 9, 2004 | 10:21 PM
Bull_head360's Avatar
my car sometimes does that weird idle thing, but i just rev on it and it stops....lol, quick fix...and yes, definatly upgrade your fuel pump
Old Jan 9, 2004 | 10:29 PM
otakueric's Avatar
my idle is everytime im in neutral...i cant just rev on it and fix it...
Old Jan 10, 2004 | 01:09 AM
otakueric's Avatar
Default Re: (otakueric)
and yes i will upgrade my fuel pump
Old Jan 10, 2004 | 05:27 AM
solsteeler's Avatar
I believe a code 14 is for iacv so either its a bad wire, bad iacv, or dirty iacv.
Old Jan 10, 2004 | 06:49 AM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: infamous honda idle...noooooooooooooooooo! (solsteeler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsteeler &raquo;</TD></TR><TR><TD CLASS="quote">I believe a code 14 is for iacv so either its a bad wire, bad iacv, or dirty iacv.</TD></TR></TABLE>
Yep. Can't believe no one said that before you..
Old Jan 10, 2004 | 08:27 AM
pdiggitydogg's Avatar
i just cleaned my iacv yesterday because i had funky idle
problem solved
Old Jan 10, 2004 | 12:14 PM
otakueric's Avatar
how do i get to the iacv?
do i have to remove the intake?
i can BARELY get to the tps sensor plug, but i dont see the iacv, is there a tutorial anywhere?
Old Jan 10, 2004 | 12:28 PM
otakueric's Avatar
also, did you have the cel before u cleaned the iacv? and it dissapeared afterwards?
Old Jan 10, 2004 | 01:06 PM
visionsOFmadness's Avatar
have un pluggen anything lately in or around the manifold
Old Jan 10, 2004 | 01:21 PM
no, I had no cel, just a surging idle
the iacv is on the back of the intake manifold
it has a black cylider on the side of it and has 2 coolant hoses as well.
connected w/ 2 bolts
(at least this is all true on my y8)
Old Jan 10, 2004 | 04:49 PM
otakueric's Avatar
well i have a cel, so im thnking it might not just be dirty?
pdiggity: do i have to remove the intake manifold to get to it? or can i reach around? or is it easier to go at it from under the car
Old Jan 10, 2004 | 04:54 PM
E-Rok's Avatar
EPIC TUNING
its right on the backof your IM. 2 12mm bolts and 2 coolant hoses.
Old Jan 10, 2004 | 08:44 PM
otakueric's Avatar
Default Re: (rewsnaeht)
am i looking at the wrong place? i cant find anything
Old Jan 10, 2004 | 09:12 PM
E-Rok's Avatar
EPIC TUNING
right on the back man, its like a little cylinder with coolant lines going to it. its the only thing back there with coolant lines on it and a harness plug on it.
Old Jan 10, 2004 | 09:17 PM
otakueric's Avatar
i feel like a retard cause i cant find it, and its really cold outside too, does anyone have a picture?
Old Jan 10, 2004 | 09:46 PM
92civeg's Avatar
number 9
Old Jan 10, 2004 | 10:42 PM
otakueric's Avatar
wow your awesome, man i cant even get to it, are my hands and arms that fat? i cant even unplug the tps plug without thing and long pliers
what should i use to clean it? distributor cleaner?
Old Jan 10, 2004 | 10:48 PM
92civeg's Avatar
carb cleaner
Old Jan 10, 2004 | 11:00 PM
otakueric's Avatar
Default Re: (92civeg)
im sure this will help my idle
but like the other guy said, he didnt even have a cel
is there anything else that could be giving me this cel and idle?
im going to clean it first thing tuesday morning (supposed to be warmer)
Old Jan 10, 2004 | 11:04 PM
92civeg's Avatar
your cel could be caused by your fuel pump problem, have you checked the code yet?
