592whp on stock port head.
Hey all just wanted to know what kinda power the B series are making on stock ported heads? We were able to produce 592whp@26psi and 408ft/tq with hondata tonight . motor specs. B18c1, AEBS T-Sleeved Ross 9.1 84mm XS T04x2 turbo. JG Turbo and intake mani 3"dp. . stock crank. Stock head with valve train. A/F is at a flat 12.0 . timing is also still kinda low. We wanna run 28-29 psi . Unfortunatly ran outta 116 tonight so have to finish up tomorrow. hoping for 610ish after more timing and couple more psi. Had the dyno chart on disc but for some odd reason it isnt working now. will post dyno chart tomorrow. here are some pics below for now. Tell me what u guys think. Minh
Valves are not stock nor are the springs and retainers. Stock port and cams. yeah this is the same car that we used for the AIR mani test. Imagine what kinda power it could make with the aid of an AIR mani.
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastEK9 »</TD></TR><TR><TD CLASS="quote">Imagine what kinda power it could make with the aid of an AIR mani. </TD></TR></TABLE>
thats what I was thinken!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastEK9 »</TD></TR><TR><TD CLASS="quote">Valves are not stock nor are the springs and retainers. Stock port and cams. yeah this is the same car that we used for the AIR mani test. Imagine what kinda power it could make with the aid of an AIR mani. </TD></TR></TABLE>
what type of valve train setup do you have then? mind sharing? what kind of "STOCK" cams are you using as well... Hey, we are all curious monkeys
Jeff
Jeff
If u think the drawings were incredable (which i dont doubt) u should see the facility that they are made at. never seen so much CF parts at 1 place simply explains why the quality in the AIR mani is TOP NOTCH.
Valves are Ferrea, gsr cams.
