ground control coilovers stuck
Old Jan 9, 2004 | 06:36 PM
Integra187's Avatar
Default ground control coilovers stuck
I was trying to adjust my front passenger ground control coilover but it seems stuck. Any idea on what to do? thanks.
Old Jan 9, 2004 | 06:44 PM
jdmkrazie's Avatar
Default Re: ground control coilovers stuck (Integra187)
man handle it. get some leverage on it. either ways you should be able to break at least the top part loose. then if the bottom one is stuck then just use something to hold the coilover housing or wuteva its called (not on the treads though) and use the coilover adjuster tool and lower the bottom sleeve. but i mean the only reason its stuck is because of dirt in between the treads. just man handle it and it'll eventually break loose.
Old Jan 9, 2004 | 07:03 PM
LS stretch's Avatar
spray that bitch up with some quick release spary, w-d-40, or this **** i seen called prolong. n e of them work great. spray a **** load of it on , let it sit over night and try breakin it loose the next day.
Old Jan 9, 2004 | 07:43 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ground control coilovers stuck (jdmkrazie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkrazie &raquo;</TD></TR><TR><TD CLASS="quote">man handle it. get some leverage on it. either ways you should be able to break at least the top part loose. then if the bottom one is stuck then just use something to hold the coilover housing or wuteva its called (not on the treads though) and use the coilover adjuster tool and lower the bottom sleeve. but i mean the only reason its stuck is because of dirt in between the treads. just man handle it and it'll eventually break loose.</TD></TR></TABLE>
GC's do not have dual perches jammed together to lock it in place. They only have a single perch w/ a locking allen-head bolt.
Old Jan 9, 2005 | 11:44 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: ground control coilovers stuck (PatrickGSR94)
Yea, i have the same problem.
Old Jan 9, 2005 | 12:35 PM
garados's Avatar
Default Re: ground control coilovers stuck (JDM_Ej)
clean off all of the funk under and over the perch with some pb blaster or something slippery. If all else fails, try to get some channel locks on it to get alittle more leverage. good luck
Old Jan 9, 2005 | 02:49 PM
cnydc2's Avatar
Default Re: ground control coilovers stuck (garados)
This happened to a freind of mine and he disassembled the shock and took the sleeve out and soaked it in kerosene and it did break the perch loose. I know it sounds weird but he said it worked very good, I never saw it. It may be of some use to you. Me personally, I would spray it with PB Blaster and use a pair of channel lock to break it loose. Good luck
Old Jan 9, 2005 | 03:04 PM
Ketone's Avatar
Default Re: ground control coilovers stuck (cnydc2)
Mine front GC coilover has locked up too. I think the only option is to take it out, and break it loose that way.
Old Jan 9, 2005 | 03:10 PM
ernald711's Avatar
Default Re: ground control coilovers stuck (Ketone)
me too... clean the crap off, then use oil...
Old Jan 10, 2005 | 10:56 PM
calxtreme's Avatar
use force, use the force.
Old Jan 13, 2005 | 08:07 AM
beedoublejay's Avatar
Make shure both front wheels are raised off the ground when adjusting the coil-overs. If you have a sway bar and one wheel remains on the ground the bar will keep the spring loaded.
peteandjenn
Classic Hondas
Aug 25, 2008 06:47 AM
MenaceL.A.671
11
Jan 15, 2007 03:56 PM
99ls
Apr 1, 2006 01:16 PM
slowr6
Suspension & Brakes
Jan 27, 2005 05:12 AM
_noname_
May 9, 2003 12:40 PM
