*** Urgent: Help with Progress rear swaybar install ***
Old Jan 9, 2004 | 06:28 PM
p0pe's Avatar
Default *** Urgent: Help with Progress rear swaybar install ***
Ok... me and a couple of friends are installing my progress rear swaybar and it's supposed to require drilling into the subframe. Once you drill the holes how do access the top of the subframe crossbeam to drop the bolts down? This is for a 97 accord ex. Any comments / suggestions appreciated!
Modified by p0pe at 10:31 PM 1/9/2004
Old Jan 9, 2004 | 07:21 PM
StyleTEG's Avatar
Default Re: *** Urgent: Help with Progress rear swaybar install *** (p0pe)
I believe you have to drop the LCA's.
Old Jan 9, 2004 | 08:59 PM
p0pe's Avatar
TTT, the instructions say nothing about dropping the crossbeam or lcas. They show them drilling up into the subframe but in the next picture, the bolts are magically dropped down from above and they're screwing the nuts on. to bad instructions!!!
Old Jan 10, 2004 | 05:39 AM
p0pe's Avatar
TTT anyone?
Old Jan 11, 2004 | 08:58 AM
vtekstorm's Avatar
hey man i think you have it mounted wrong. try taking the sway bar and putting the ends hang above the control arms instead of under. doing that should change the postion sway bar to be mounted.
chargedek
Sep 7, 2010 12:50 PM
bellmy2007
Suspension & Brakes
Mar 12, 2006 12:55 AM
Civicpmp04
28
Jan 31, 2006 08:27 AM
p0pe
Jan 13, 2004 12:36 PM
