b16 2nd gen tranny notchy
Old Jan 9, 2004 | 04:03 PM
doublejz's Avatar
Default b16 2nd gen tranny notchy
Ok so i have a b16 2nd gen with whatever tranny came with it it has a kaaz lsd in it. I am running kaaz fluid which is 85w-90 thick as hell. When its cold I can barely get it outt or in a gear. Even after its warmed up every gear doesn't really grind but I can feel it going in like its "notchy" or something. I doubt all the syncros went at once. I was thinking gm syncromesh or redline or something but I'm worried about the lsd and the fluid is gonna be too light. Any ideas?
Old Jan 9, 2004 | 08:39 PM
doublejz's Avatar
Default Re: b16 2nd gen tranny notchy (doublejz)
ok so on my way home i decided to start double clutching to see if that helps, sometimes it does sometimes it doesn't
Old Jan 10, 2004 | 06:45 AM
Burke's Avatar
Banned
thats really thick. stock they use a 10w-30, have you tried swapping out the oil at all to see if that fixes it? maybe your forks were misaligned when it was put together with the lsd
hth
where in pgh, im from penn hills
Old Jan 10, 2004 | 08:29 AM
doublejz's Avatar
Default Re: b16 2nd gen tranny notchy (Burke)
i put kaaz fluid in and it was like $55 for 2 quarts, and I know I'll never be able to catch every bit of it when I drain and decide to reuse it to refill it.
Old Jan 10, 2004 | 08:30 AM
doublejz's Avatar
im really close to greensburg but pittsburgh sounds so much better
Old Jan 10, 2004 | 08:39 AM
Burke's Avatar
Banned
wow 55 for 2 quarts. if it was me, i would prolly drive it for a couple weeks to see if things loosened up before i poured 55 down the drain. good luck
Old Jan 10, 2004 | 08:43 AM
mmuller's Avatar
Mad Scientist
try gm synchromesh with friction modifiers, great stuff.It helped greatly on mine. not as notchy as before.
85w90 is way too thick
JDMCRX05
Jul 14, 2006 10:36 PM
ELAMINT5
Jul 21, 2004 05:13 PM
doublejz
Sep 27, 2003 09:13 AM
ZERO COOL
Jan 17, 2003 12:35 PM
JDM CRX
Jan 10, 2003 04:01 PM
