got wheel hop?
ive recently had an h22 put in my 95 accord ex coupe, and ive got aweful wheel hope on takeoff. My suspension setup is tokico full coilovers lowered about 1.5 inches all around, set on 3 on a daily basis. Does anyone else have this problem or suggetions? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typertn »</TD></TR><TR><TD CLASS="quote">ive recently had an h22 put in my 95 accord ex coupe, and ive got aweful wheel hope on takeoff. My suspension setup is tokico full coilovers lowered about 1.5 inches all around, set on 3 on a daily basis. Does anyone else have this problem or suggetions? thanks</TD></TR></TABLE>
How are you motor mounts ?
Try urethane inserts, a good spring rate, and set your shocks to #5.
I have no wheel hop at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Escobar »</TD></TR><TR><TD CLASS="quote">
I agree with him. I had my suspension turned all the way up and I didn't experience any wheel hop until the front and driver motor mount bolts broke inside of the block. It wheel hopped majorly for those couple miles until I could figure out what was wrong. It isn't the fault of the stiff suspension, just another mistake in an already bad h22 swap.
I cant recall, does anyone know which mount is differnt on the prelude swap, it seems like i remember that two one of the mounts was a prelude one, does anyone know? thanks
im working on some traction bars for Accords with a fabrication friend of mine. im a drag racer at heart but these bars will be copatible with daily driving as well. they will virtually eliminate wheel hop.
i will be sure to update as things progress.
