Mugen Rear SWay Bar ripping apart subframe?
Hey guys, I was told if you put a Mugen or even a Type R rear sway bar in a non R it will rip apart the subframe. Is this true? Anyway to correct this?
Guest
Posts: n/a
Any larger sway bar CAN have the ability to tear the subframe. Fortunately for me, I've never had that problem. BUT if you want to be on the safe side, get the Beaks or BSQ swaybar mount kit.
Yup, My friend's 94 GSR bought the R's rear sway bar from the dealer and by using same factory mt pts end up ripping a big hole on the center subframe. That is why places like comptech charge u lot more for the whole kit because it includes subframe reenforced mts plates to aid the GSR thinner subframe.
ed lee
Y2K ITR #498
97 ITR #315 RIP
ed lee
Y2K ITR #498
97 ITR #315 RIP
Yep, the ITR has a hole new system to make sure that it doesn't rip the subframe, make sure you get similar mounts and brackets.
Please refer to my step-by-step installation instructions on my website ( http://www.geocities.com/bretq/swaybar_install.html ) for installing a Type-R rear swaybar on a non-Type-R Integra. You will see that my instructions have eliminated the stock mounting bracket and uses new mounting plates which allows the Type-R rear swaybar to be mounted DIRECTLY subframe. The mounting plates also reinforces the subframe sheetmetal.
Where can I find these parts at? Do you have a url so I can see what the
going price is and whats included in the kit?
Guest
Posts: n/a
I knew you'd show up sooner or later to answer these questions.
So what gives? Am I just a luck ****? I've had my ITR bar on my EX for almost 3 years now, and no problems. And yes, I abuse my car on the street and track. I've even had the damm thing spin out on me from time to time.
FYI, I have had my Type-R rear swaybar installed for 3.5+ years now and I have 21+ hours of track time on it and I haven't experienced any problems.
Ok I visited your site, it said it was for 92-95 Civics, I will be installing a Mugen rear sway bar on a 2000 Civic DX Hatchback. Will your kit still work or not?
I got it mounted like this.
Well I visited Kings site, they have a rear sway for the DX, but its $100 more. I wonder why? Also, heres what Kings say-
This stabilizer minimizes vehicle rolling during cornering by creating a spring-like effect due to its twisting. The original type stabilizer allows steering characteristics to be tuned by selecting the thickness and hence the wheel rate. The kit also includes two stabilizer bushes for the body mountings. The rear stabilizer kits are supplied with a chassis reinforcement kit.
Does anyone know for sure if this is the kit I'll need so I dont rip apart my car?
Just for a second opinion, I have the BSQ kit installed for about a year now and it's working like a charm. If your looking to save money get the BSQ kit it does it's job like a champ.
BSQ- whats wrong with using this method of install?
http://www.hybrid.honda-perf.org/tech/ITRon6G.html
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
bsq, i did my swaybar similaiar to your, but with a beefier front bracket.
i have been running a 26mm mugen bar for quite some time with stock itr suspension, and now RG coilovers. so far, so good.
