Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Ways to remove oil spots from driveway and garage floor?
Old Jan 9, 2004 | 03:04 PM
Tyson's Avatar
Default Ways to remove oil spots from driveway and garage floor?
i finally sold my 280Z that i bought and never got the project off the ground. whats left behind is a nice oil spot from it sitting for over a year. anyone have ideas of what to do to at least minimize the stain? driveway is porous concrete, not asphalt.
also, id like to clean up the garage floor. any extra special ideas for the garage floor since its by nature a bit different concrete than the driveway.
i rent out this house and feel bad for my friend/landlord for messing up his driveway and garage, eventho he's a real understanding and tolerant guy.
Old Jan 9, 2004 | 03:08 PM
cbstd's Avatar
Default Re: Ways to remove oil spots from driveway and garage floor? (Tyson)
Kitty Litter picks up oil and will minimize the stain.
Old Jan 9, 2004 | 03:14 PM
rapid_roy's Avatar
I believe muriatic acid is for cleaning concrete but I have never tried it myself.
I have used a nasty chemical in a can called C-60, and I haven't found anything oil or grease related that stuff won't make go away. Carb cleaner or engine degreaser would also work if you can't find C-60.
C-60 here: http://www.kengseng.com/spraylist.asp
Cheers,
Sean
Mike P.'s Avatar
25 Year Member
I've had good luck with kerosene and a wire brush. You may want to give that a shot.
Old Jan 9, 2004 | 03:28 PM
ITAcelica's Avatar
In Autozone they have this stuff its called driveway cleaner, its in a white plastic can that looks like antifreeze. That worked very will for me.
Old Jan 9, 2004 | 03:40 PM
Vitt1's Avatar
Default Re: (ITAcelica)
I tried a strong solution of Simple Green with a brush and it did a pretty decent job on concrete. I think I just poured some concentrate on there, then let it sit for a bit before brushing and rinsing. I didn't have large puddles of oil though. I'd try this after the kitty litter.
Old Jan 9, 2004 | 04:47 PM
BsmoothR's Avatar
Default Re: (Vitt1)
A cleaning products company called ZEP makes industrial streghth soap,
Old Jan 9, 2004 | 05:20 PM
kurt.'s Avatar
Default Re: (BsmoothR)
Castrol Super Clean
Not the wheel cleaner, but the heavy duty stuff. I sprayed (a lot of) it directly onto the concrete let it sit for 15 minutes then hosed it off. Voila! If I had to use a brush, I used it sparingly only on the tough spots that remained.
Old Jan 9, 2004 | 10:40 PM
mityVR6's Avatar
Default Re: (Vantage)
Gasoline. Seriously.
Old Jan 10, 2004 | 12:17 AM
Bbasso's Avatar
Default Re: Ways to remove oil spots from driveway and garage floor? (cbstd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbstd &raquo;</TD></TR><TR><TD CLASS="quote">Kitty Litter picks up oil and will minimize the stain. </TD></TR></TABLE>
And to further help the kitty litter, get a regular brick and rub the kitty litter into the spot with a little force, the pressure and the wieght of the brick does a lot.
Old Jan 10, 2004 | 01:05 PM
CRX Lee's Avatar
Default Re: Ways to remove oil spots from driveway and garage floor? (Bbasso)
Many years ago I used some cheap powdered laundry soap, made a gritty paste witgh a little water and rubbed it in with a stiff bristle brush. Did that a few tiems rinsing in between and it did a pretty good job. If you have some in the house, you might try it and save a trip to the store and a purchase.
Old Jan 11, 2004 | 11:24 AM
SicNA94TegGsR's Avatar
Swollen Member
Not gonna read all the posts, somone may have written this already, but when my parents got their driveway paved with bricks, they gave them good ole Oxy-Clean for any stains....might help
Old Jan 11, 2004 | 02:36 PM
Nfurno's Avatar
Default Re: Ways to remove oil spots from driveway and garage floor? (SicNA94TegGsR)
Set dry powdered dishwashing detergent (like Cascade) on the stain, rub it in then pure some more. Let is sit overnight, then pour boiling hot water on it and scrub it with a wire brush.
The dishwashing detergent soaks up some of the oil and the hot water opens up the pores in the concrete.
Old Jan 11, 2004 | 03:39 PM
JoelG's Avatar
Default Re: (mityVR6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mityVR6 &raquo;</TD></TR><TR><TD CLASS="quote">Gasoline. Seriously.</TD></TR></TABLE>
dont do that. seriously. I know a guy that burned his house down cleaning something with gasoline.
If you want a cheap solvent, use kerosene. Its a lot safer. Still not as safe as oil dry followed by a strong detergent.
Old Jan 11, 2004 | 04:14 PM
Lo-Buck EF's Avatar
Default Re: (Vitt1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vitt1 &raquo;</TD></TR><TR><TD CLASS="quote">I tried a strong solution of Simple Green with a brush and it did a pretty decent job on concrete. I think I just poured some concentrate on there, then let it sit for a bit before brushing and rinsing. I didn't have large puddles of oil though. I'd try this after the kitty litter.</TD></TR></TABLE>
DVS Luder
Paint and Body
Aug 7, 2008 12:31 PM
Tip14
Oct 14, 2007 01:10 PM
Phire
Apr 15, 2004 05:52 PM
diluted
Jan 12, 2004 04:58 AM
89 CRX SI
Aug 31, 2002 09:07 PM
