EP3 Camber Kit
Old Jan 9, 2004 | 12:30 PM
SiRocket02's Avatar
Default EP3 Camber Kit
First... I have an '02 Si w/ 17 in wheels and Eibach Pro Kit drop springs 1" (F), 1.1" (R) If anyone else has done this, I'd like to know how bad i need a camber kit. To me the negative camber is pretty obvious and I'm concerned with the tire wear issue. Could someone tell me which camber kit would be best for the rear. (thought im sure it would be the kit eibach makes for the Pro Kit springs). Also, would the camber kit for the rear of a 96-00 civic ex fit? I havent looked, but i have one available. Thanks.
Old Jan 9, 2004 | 12:47 PM
civicvtec1ps's Avatar
Default Re: EP3 Camber Kit (SiRocket02)
Camber kits that are made for 6thgen civics wont work.Just go with SPC rear camber kit,
Old Jan 9, 2004 | 05:01 PM
Peking's Avatar
Default Re: EP3 Camber Kit (civicvtec1ps)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicvtec1ps &raquo;</TD></TR><TR><TD CLASS="quote">Camber kits that are made for 6thgen civics wont work.Just go with SPC rear camber kit,
Yeah, what he said.
Old Jan 9, 2004 | 07:43 PM
03 civic si hb's Avatar
i have a friend with an 03 si with the prokit and no camber kit and he says his camber is just fine with no unusual wear on his tires. once he got the springs installed he let them settle for about 3000 miles or so and then went to NTB to get an allignment done and they said he was still in honda specs for that car and was fine.
Old Jan 9, 2004 | 07:59 PM
Jim Truett's Avatar
Default Re: EP3 Camber Kit (03 civic si hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03 civic si hb &raquo;</TD></TR><TR><TD CLASS="quote">i have a friend with an 03 si with the prokit and no camber kit and he says his camber is just fine with no unusual wear on his tires. once he got the springs installed he let them settle for about 3000 miles or so and then went to NTB to get an allignment done and they said he was still in honda specs for that car and was fine.</TD></TR></TABLE>
It doesn't sound like they checked the rear camber. I have the Pro-kit and that left me with negative 1.5 degrees camber in the rear. The track angle was off also.
Old Jan 9, 2004 | 08:27 PM
chunky's Avatar
Default Re: EP3 Camber Kit (Jim Truett)
stock spec for camber in the rear is -1.3 to -1.7
prok kit will leave you well within that range. 2" drop that my h&r springs resulted in yielded only -1.7 rear camber. still within stock spec.
of course I wouldn't reccomend that you run -1.7, but it won't wear the tires that fast, and it's within stock spec.
Old Jan 9, 2004 | 08:47 PM
Jim Truett's Avatar
Default Re: EP3 Camber Kit (chunky)
Stock spec for rear camber according to the helms manual is -0*45' or basically -.5 degrees. Front spec is straight up at 0 degrees.
Old Jan 10, 2004 | 07:20 AM
chunky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">Stock spec for rear camber according to the helms manual is -0*45' or basically -.5 degrees. Front spec is straight up at 0 degrees.</TD></TR></TABLE>
hmm. interesting. the alignment shop I went to has the stock spec printed as -1.3 to -1.7.
in the helms manual, section 18 page 6,
rear camber angle is specified at -55 minutes +/- 45 minutes. That means that the camber spec is -1 degree to -.17 degrees.
Old Jan 10, 2004 | 09:50 AM
glw's Avatar
glw
chunky is correct!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunky &raquo;</TD></TR><TR><TD CLASS="quote">
...in the helms manual, section 18 page 6,
rear camber angle is specified at -55 minutes +/- 45 minutes...
but the helms also has -0°45' +/- 45' on page 2-9 specs...
in any case with page 2-9, (i think there are 60' per 1°) the limit would be between straight up 0°0' to -1°30' (or -1.5°). mine is at -1.9° left and -2.0° right with eibach sportlines and i haven't put a kit on. maybe i won't - the ep3 feels great at autox and the tires don't seem to wear becasue of the camber...
toe is important in tie wear - mine is neutral or as close to 0 as possible.
Old Jan 10, 2004 | 02:28 PM
SiRocket02's Avatar
My car has no noticable front camber. Only the rear is noticeable, but not real bad. A couple days ago, after driving home a little over 30 miles, I got out of my car and noticed the rear tires smelled a little like burning rubber, but weren't hot..im guessing this is a camber problem wearing out the inside of the rear tires. So help me out with the correct kit to buy here, will ya?
Just wondering....when moving at slow speeds, and i turn the wheel hard either direction, i hear the front left spring pop occasionally. Could this just be the spring breaking in...or should i reseat the spring?
Old Jan 10, 2004 | 05:31 PM
i'm not sure what to tell ya, i've had mine on for over a week now(prokit) and haven't smelled anything. as far as a camber kit for them it seems to be a matter of opinion. take it to a shop and get a 4 wheel alignment done and see what specs they come up with and go from there, that's what i'm going to do in the spring.
Old Jan 10, 2004 | 08:46 PM
vtecvoodoo's Avatar
Future Texas Boy
You don`t need a camber kit with a pro-kit.
Old Jan 10, 2004 | 10:37 PM
SiRocket02's Avatar
Default Re: EP3 Camber Kit (vtecvoodoo)
I have a friend with an RSX Type S. He also has the prokit springs and has driven the car for about 5 months without a camber kit. The camber looks about the same on both cars. Tire wear doesnt seem to be bad on his car. I guess its just my personal preference to buy one.
Old Jan 10, 2004 | 10:38 PM
SiRocket02's Avatar
So, I should get an alignment done and just see what they say about needing a camber kit? My alignment is fine though, no shaking, and the cars doesnt pull either direction
Old Jan 11, 2004 | 09:24 PM
SiRocket02's Avatar
haha, i got a new icon.
Conclusion
Suspension & Brakes
24
Aug 28, 2008 05:13 PM
JTaudio0212
Honda Civic (2006 - 2015)
18
Oct 25, 2007 04:58 PM
wwong510
Feb 13, 2007 11:11 PM
fafsa
Apr 6, 2005 03:40 PM
