How to tell cable LS tranny or gsr tranny
Old Jan 9, 2004 | 11:54 AM
HatchBox's Avatar
Skoobie no more...
Default How to tell cable LS tranny or gsr tranny
well how do you? thank you
Old Jan 9, 2004 | 12:32 PM
mr.beeks's Avatar
Default Re: How to tell cable LS tranny or gsr tranny (ind3ciso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">well how do you? thank you
LOL
if you are talking about 92-93
the code will be YS1
but if you are talking about the 94 after they are hydraulic not quite sure of
the code..
Old Jan 9, 2004 | 12:33 PM
arw321's Avatar
Default Re: How to tell cable LS tranny or gsr tranny (mr.beeks)
YS1 is the code for 92-93 GSR and NON GSR tranny's. The code is the SAME on both.
So, externally there is no real way of telling. So hope you bought from a trustworthy source, or open it up and start counting teeth.
Old Jan 9, 2004 | 12:47 PM
HatchBox's Avatar
Skoobie no more...
Default Re: How to tell cable LS tranny or gsr tranny (arw321)
yes im talking about the 92-93 cable trannys
its marked YS1
are the imput shafts the same size? Because my 90-91 ls clutch plate wont fit on the imput shaft, i have heard that the grs is the only b series to have the larger imput shaft but im not sure if thats true
Old Jan 9, 2004 | 02:01 PM
JDMHN8's Avatar
This is fact, so listen up and take notes:
1989-91 B-Series Cable trannies:
USDM A1/S1 from the DA Integra
JDM Y1/S1/J1 from the DA Integra and EF Civic/CRX
All have a 25mm input shaft. You must use a clutch from a 1990-91 Integra. Parts are very hard to find. I'd avoid them, but that's me.
1992-01 Cable and Hydro trannies
USDM cable YS1 long (LS) and YS1 short (GSR)
JDM cable YS1 short (XSi/RSi)
USDM hydro Y21, S4C, S80 etc.
JDM hydro Y21, S80, S4C, etc.
All have a 26mm input shaft and use any clutch from a 1992-01 Integra. All parts can be swapped among them, except cable trannies need slight mods to fit the hydro internals.
There is no way to tell the USDM YS1s apart. If you had a JDM YS1w/ LSD, that would be very easy. Rip it open if you really want to know. Or install it and see where your tach is at 80 MPH in 5th gear. The short YS1s are the shortest geared B-series trannies (not by much, though) except for the final drive ratio...
Old Jan 9, 2004 | 02:11 PM
HatchBox's Avatar
Skoobie no more...
Default Re: How to tell cable LS tranny or gsr tranny (JDMDA9)
guess i have to take it apart. i would like to sell it legit, once i take housing off , what am i looking for?
Old Jan 9, 2004 | 02:13 PM
JDMHN8's Avatar
Well, the easiest way is to count the teeth on the final drive. I don't know the exact numbers of teeth, though.
LS- 4.266:1
GSR- 4.400:1
EXRex
Oct 9, 2007 08:24 PM
98IntegraLSNonVtec
Feb 10, 2006 06:26 PM
acurar0ss
Feb 16, 2004 11:08 PM
schtozo
Feb 21, 2003 11:48 AM
HybridRexy
14
May 4, 2002 11:19 AM
