skunk2 intake manifold install on GSR motor...
Old Jan 9, 2004 | 09:42 AM
TRE_'s Avatar
Default skunk2 intake manifold install on GSR motor...
any tips or how-to guides you guys know of for installing a skunk2 intake manifold on a gsr motor? sorry if this is the wrong forum. thanks in advance for any help.
Old Apr 16, 2004 | 03:53 AM
1SlowSi's Avatar
Default Re: skunk2 intake manifold install on GSR motor... (THE_HX)
Sorry to jack your thread but i gotta question,. When you throw a GSR motor in a 99Civic Si obviously you cant use a CAI made for an Si, you have to use a short ram, because the GSR manifold sits lower. If i buy the Skunk 2 manifold, can i THEN use **** made for an Si? I.E. CAI, Intercooler piping? Being that you have rubber couplers, cant you use civic intercooler piping and just push the charge pipe down a few inches to mate up to the TB?
Old Apr 16, 2004 | 04:18 AM
TurboBumblBee's Avatar
Default Re: skunk2 intake manifold install on GSR motor... (1SlowSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE_HX &raquo;</TD></TR><TR><TD CLASS="quote">any tips or how-to guides you guys know of for installing a skunk2 intake manifold on a gsr motor? sorry if this is the wrong forum. thanks in advance for any help. </TD></TR></TABLE>
do a search in the integra forum, i remember seeing something a couple months ago that was very helpful...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">Sorry to jack your thread but i gotta question,. When you throw a GSR motor in a 99Civic Si obviously you cant use a CAI made for an Si, you have to use a short ram, because the GSR manifold sits lower. If i buy the Skunk 2 manifold, can i THEN use **** made for an Si? I.E. CAI, Intercooler piping? Being that you have rubber couplers, cant you use civic intercooler piping and just push the charge pipe down a few inches to mate up to the TB?</TD></TR></TABLE>
yes that would work.. i ran into the same problem w/ my turbo kit.. it was designed for a gsr into a 5gen civic (drag3 hybrid kit) but it wasnt made for a gsr w/ a skunk2 IM so we had to do a little cutting on the pipes and get some couplings..
Old Apr 16, 2004 | 04:46 AM
HT Chaplain's Avatar
Loved
i did it. It was pretty easy and straight foward the only thing was i did it on the engine when it was out of my car sitting on a crate. It will probably be hard scrapping the old gasket off the engine when you take the stock manifold off. That probably the most important step. Make sure ALL the old gasket material is off before putting the skunk2 manifold on or you might have leaks
Modified by legutki at 10:06 AM 4/16/2004
Old Apr 16, 2004 | 05:54 AM
IN VTEC's Avatar
All the GS-R Skunk2 IM notes are archived in the Integra forum.
Old Apr 16, 2004 | 06:46 AM
Muckman's Avatar
Moderator in Chief
https://honda-tech.com/zerothread?id=451235
no pics but the steps are still helpful.
Old Apr 16, 2004 | 01:37 PM
TRE_'s Avatar
Default Re: skunk2 intake manifold install on GSR motor... (Muckman)
lol, i posted this thread like 3 months ago, and ended up just installing the manifold without any real instructions... it was pretty simple!
Invisible01GSR
Nov 16, 2004 05:47 PM
stehigs321
Nov 29, 2002 06:59 PM
