Ok..A real stupid question, but oh well.
Old Jan 9, 2004 | 09:10 AM
davezintegra's Avatar
Default Ok..A real stupid question, but oh well.
My 88 Integra over heats with a thermostat installed....(Ive put three new ones in & now have a OEM unit in it)....Ive got a new radiator, water pump and new switches & Ive flushed the system twice!....the lower hose NEVER gets warm ..UNTILL I remove the thermostat!! (Ive even purged the air out 10,000 times!) Question is: Is the thermostat located at the upper hose (exiting the motor) or Lower hose (going back to the motor)???...I think I may have in in the wrong housing....duhh.
Dave.
Old Jan 9, 2004 | 11:06 AM
xxxmikenicexxx's Avatar
Default Re: Ok..A real stupid question, but oh well. (davezintegra)
The bottom
Old Jan 9, 2004 | 11:15 AM
Default Re: Ok..A real stupid question, but oh well. (xxxmikenicexxx)
Sigh..... thats where its been......any idea why it overheats with a thermostat?....keeping in mind its a brand new Acura OEM thermostat...($25.00)
Ive been runnning the car all morning at idlle without the stat & it runs perfectly cool.
Old Jan 9, 2004 | 11:29 AM
JimBlake's Avatar
You got the gasket messed up? The gasket has a slit around the inside, so it fits over the edge of the T-stat. That way you don't need a separate gasket on both sides. If you get it wrong, it'll block the T-stat from opening.
Also, there's a little hole in the T-stat with a little pin rattling around in it. That has to be oriented towards the top. If that's blocked, your t-stat will never see the warm water so it won't open.
Old Jan 9, 2004 | 11:55 AM
Dan GSR's Avatar
Default Re: Ok..A real stupid question, but oh well. (JimBlake)
it is also possible to install a t-stat backwards
Old Jan 9, 2004 | 11:59 AM
Default Re: Ok..A real stupid question, but oh well. (Dan GSR)
Thanx..Ill make one last feeble attempt.....orientating it so the rattle pin up is tough in that confining of a space but I had it close.....also, the tstat only fits in one way on mine, the spring end wont fit the other way.
Old Jan 9, 2004 | 12:02 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davezintegra &raquo;</TD></TR><TR><TD CLASS="quote">... also, the tstat only fits in one way on mine, the spring end wont fit the other way.</TD></TR></TABLE>Yes. I bet they did that on purpose...
My T-stat housing has a little depression, so the rattle-pin only fits one way, too. But the rattle pin is easier to force in wrong, if you're not paying attention. And the gasket has a little cut-out for the rattle-pin.
acetrade11
11
Sep 15, 2012 07:38 PM
Tzarinque
Nov 30, 2008 03:12 PM
99fbpem1
Sep 18, 2007 11:07 PM
slickrc
Feb 6, 2004 10:16 AM
riceboyEFsi
Dec 28, 2003 04:06 AM
