bad 02 sensor?
Old Jan 9, 2004 | 07:11 AM
93coupeDX's Avatar
Default bad 02 sensor?
Can someone tell me what some of the symptoms of a bad 02 sensor are. Does your car run really bad or does the check engine light just come on? If it varys from different cars and engines, I have a 93 civic coupe dx with a d15b7 in it and I just put an airmass header on it and now the check engine light is on. I did reuse the old 02 sensor but it's only 8 months old or maybe with a header I need and aftermarket one?
Old Jan 9, 2004 | 07:17 AM
redlinetuning's Avatar
Default Re: bad 02 sensor? (greenjunk)
you either have a leak at the flange where the O2 sensor is bolted, or you have a bad sensor.. otherwise you can try taking fine grit sndpaper to clean it off..
Old Jan 9, 2004 | 07:22 AM
SleepnCiViC's Avatar
find out the code
Old Jan 9, 2004 | 07:44 AM
Jimmy's Avatar
Global Moderator
reset your ecu and see if that works.
take off the neg. battery cable for like 5 mins and then crank it up.
Old Jan 9, 2004 | 08:03 AM
TeamNextGenChris's Avatar
i doubt a bad sensor is your culprit.sounds like you either forgot to plug some sensor back up,or maybe you turned the key on while you had the O2 unplugged,storing the code.
check your codes and tell us what you have,or try resetting the ECU and it should go away.
chris
Old Jan 9, 2004 | 08:12 AM
hondachick81's Avatar
Default Re: bad 02 sensor? (TeamNextGenChris)
at what point <u>would</u> the light come on indicating a bad o2??
I still have my original o2(primary) and my car has 96k miles.
I am sure it is fried!!!! I was planning to replace it 30 some miles ago, but the price scared me...and I never ended up doing it.
Otherwise, what I am asking is.....I am sure mine is trash, but since my light has not come on indicating a bad o2....how is this effecting my cars performance. The engine's got to know the sensor is crap.
ya know what I am saying??
Old Jan 9, 2004 | 08:19 AM
Default Re: bad 02 sensor? (civicgirl114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgirl114 &raquo;</TD></TR><TR><TD CLASS="quote">at what point <u>would</u> the light come on indicating a bad o2??
ya know what I am saying?? </TD></TR></TABLE>
from my past experience,the O2 can be bad and not throw a CEL.i have seen a coupel extreme cases where it did.usually partial throttle engine performance will suffer when the sensor starts going bad.
check into a universal O2(doesn't have a plug,you can just swap yours over)sensor at your local auto parts store.usually,they have a decent price.just to give you an idea,Advance Auto Parts lists a Bosch universal for $59.99...
chris
Old Jan 9, 2004 | 09:00 AM
spencedogg's Avatar
Hey green use this oem product number and save yourself some money it will work for ya
36531-PLM-A01
Should be no more then 50bucks
Old Jan 9, 2004 | 09:11 AM
Default Re: bad 02 sensor? (spencedogg)
wow!$29.49 for that part on Hparts.com.
what car is that from?i can't find any info on it.
chris
Old Jan 9, 2004 | 09:20 AM
spencedogg's Avatar
Im not sure but a friend of mine BERT-O on here works at acura and gave me that number
Old Jan 9, 2004 | 09:24 AM
Default Re: (spencedogg)
hrrmmm....$59 and $29
honda quoted me $120 something....and napa was like $80-$120.
thats a little much
maybe I shall check out advance auto or discount auto parts
Old Jan 9, 2004 | 09:25 AM
hmmm,anybody know?
do you know if that is a 4-wire sensor?
chris
Old Jan 9, 2004 | 09:27 AM
spencedogg's Avatar
yes 4 wire
WSBowles
Honda CR-V & Element
Apr 12, 2017 04:11 PM
skuba
Engine Management and Tuning
Jan 18, 2010 05:45 PM
mierock
Honda Civic (2001 - 2005)
Jan 7, 2009 02:55 PM
Lewie
Jun 29, 2004 09:11 AM
HATCHFREEK
Mar 19, 2003 10:32 AM
