Integra suspension in 97 civic CX
I already did a search on this. I was just wondering, will the suspension system in a 97 integra fit on a 97 civic CX. My GSR was totaled but the suspension is fine.
Thanks ahead of time
almost everything will fit. what you won't need are the lca's.. the rear trailing arms will fit.. if you choose to use the rear lca's they'll fit too.. the front's will be a little tricky.. you'll want to use the 99 si front lca/sway bar/forks instead.. it's bigger.
Thanks for the info. I'm wondering if the Springs and Shocks will fit onto my civic. Will it not be as low because of the wieght difference? Anything else I sould worry about?
spoink
Jun 12, 2006 04:17 PM
JDMCRX
May 15, 2003 07:51 PM
