my 1/2 done turbo hf manifold..what yall think (56k wurth the wait ; )
This is the HF manifold that im modifying for turbo. Just sandblasted it today, was full of rust. still needs turbo flange and Wg flange.....
close front view of manifold, notice anything diff?
sideish view
Top view
pics of the runners i ported, in the process of polishing
Close up of runner, still needs a little work
Bottom of manifold, my initials on the left and fixed a minor crack on the right. went over it a few times thats why weld looks kinda sloppy.
front view couple feet away, kinda blury
what do you think?
sideish view
Top view
what do you think?
don't forget to use the little L brackets that come on that thing stock. They help support your massive turbo and bolt right on to those threaded bosses on the bottom. Did you gasket match it or just clean up th inlets?
They won't prevent you from using it but I know you can at least put the passanger side one on and possibly the other one. The more bracing the better for durability. You could probably get one for free some where, or just make one out of L shaped steel stock. bracing the turbo directly might be even more productive though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitsuman »</TD></TR><TR><TD CLASS="quote">close front view of manifold, notice anything diff?
You grinded off the mounting holes for the stock heat sheilds...heheh..
What do I get?
What do I get?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbaZ »</TD></TR><TR><TD CLASS="quote">Sometimes those mounting holes are not there on some blocks for those supports, FYI..</TD></TR></TABLE>
thnx so i guess i can just make some braces?
you get a cookie
anybody have pics of others that have done the same thing?
you get a cookie
Looks good.. Im doing the same exact setup as you are.. I just finished building my adapter and tonight im going to do some fitment to see how everything looks.. Ill try to find access to a digital camera and post some pics of my adapter plate.. I hear you should really port out the openings to the exhaust manifold gasket..
Sure thing.. Ill also break out the measuring tape so you can get an idea on the dimentions of the adapter.. Have you been to homemadeturbo.com and looked at what they have, thats where I got the idea from.. Use 3/4" mild steel for the adapter..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">Sure thing.. Ill also break out the measuring tape so you can get an idea on the dimentions of the adapter.. Have you been to homemadeturbo.com and looked at what they have, thats where I got the idea from.. Use 3/4" mild steel for the adapter.. </TD></TR></TABLE>
ya ive gone there. they got some nice adapter plates. i kinda wanna make my own though. where can i find 3/4 in steel?
ya ive gone there. they got some nice adapter plates. i kinda wanna make my own though. where can i find 3/4 in steel?</TD></TR></TABLE>
Errr.. Dont know where to find the steel at.. My dad is a machinist
.. So thats where my adapter came from but I would say to try maybe a machine shop or metal supply company or something like that..
Ohh.. And by the way I did the test fitting this weekend.. PAIN IN THE *** is all I can say.. There is less then 1/4 inch between the radiator and the compressor housing right now.. I had to bend out the radiator support a little bit to make it fit in there.. But then again my radiator support was bent in a little bit from an accident the previous owner had with it so yours might not need any bending.. I couldnt get the turbo and manifold together past the radiator so then I tried putting just the turbo in there without the studs from the adaptor plate and it fit.. But its a pain to put the turbo on to the manifold working around the radiator.. I found the simplest way was to pull the radiator out of the car and install the turbo and manifold as one piece and then put the radiator back in.. If you do that leave the compressor housing loose so you can rotate it a little bit to get the radiator in..
Sorry for the long post but just wanted to let you know the problems we ran into and how we fixed them..
.. So thats where my adapter came from but I would say to try maybe a machine shop or metal supply company or something like that.. Ohh.. And by the way I did the test fitting this weekend.. PAIN IN THE *** is all I can say.. There is less then 1/4 inch between the radiator and the compressor housing right now.. I had to bend out the radiator support a little bit to make it fit in there.. But then again my radiator support was bent in a little bit from an accident the previous owner had with it so yours might not need any bending.. I couldnt get the turbo and manifold together past the radiator so then I tried putting just the turbo in there without the studs from the adaptor plate and it fit.. But its a pain to put the turbo on to the manifold working around the radiator.. I found the simplest way was to pull the radiator out of the car and install the turbo and manifold as one piece and then put the radiator back in.. If you do that leave the compressor housing loose so you can rotate it a little bit to get the radiator in..
I saw that they are on mine when we did the turbo test fit this weekend.. I have a d15b7 block from a 93' civic dx..
liljames
Apr 8, 2010 01:19 PM
got any of the other parts yet?
