NEED HELP! does the passage for the cam journal bolts lead to the block?
Old Sep 27, 2001 | 07:01 PM
Lei Siew Long's Avatar
Default NEED HELP! does the passage for the cam journal bolts lead to the block?
i was tightening the longer bolt for the cam journal with a torque wrench when the threaded part of the bolt snapped and i can't seem to retrieve the snapped end of the bolt. need help. thank in adv
Old Sep 27, 2001 | 07:06 PM
Sonic's Avatar
Default Re: NEED HELP! does the passage for the cam journal bolts lead to the block? (boostedeg6)
Ouch...that sucks. It doesn't go through the head, you'll have to drill a small hole in it and try to back it out. Just make sure not to drill into the side of the hole, heads are expensive.
Old Sep 27, 2001 | 07:17 PM
earl's Avatar
The passage does not go thru to the block. It is closed at the bottom. Go to an auto parts store and buy an easy out. The parts guy will help you pick the right size and proper drill bit. Spray some of that thread loosener stuff down the hole. Drill a hole in the center of the broken bolt and then screw in the easy out. It screws in counter clockwise and when it grabs the broken bolt, keep turning and your broken bolt is out. Just did one of these. Buy the replacement bolt from Honda. Be sure to get the same length as the others.
YOU CAN DO THIS! IT'S EASY!
EARL
Old Sep 27, 2001 | 07:18 PM
Default Re: NEED HELP! does the passage for the cam journal bolts lead to the block? (earl)
thanks guys, i appreciate all the help.
maximus20895
Honda Civic (2006 - 2015)
Jun 17, 2012 07:00 AM
runderwo
Aug 22, 2006 11:40 AM
sph33r
May 28, 2006 05:59 PM
phyzJunkieCivic
Mar 11, 2006 05:49 PM
93preludes
Dec 4, 2003 01:58 PM
