Finally got some dyno tunning in, charts inside!
Yep so i finally got my car put back together after months of down time, i was already turbo putting down 275hp and 206tq, at 10.5 , 11 lbs. Now darton sleeves and new arias pistons and a 2.0l engine later here are the new results
300.2 hp
251.5 tq
mods are Ls/vtec 2.0L, xs t3t4 turbo at 15lbs, hondata program, pistons, rods, sleeved block, and the list goes on
here is the car
Finally decided to post something since i'm selling the car soon.
300.2 hp
251.5 tq
here is the car
Sure something isn't wrong? Most LS/VTEC's I see with built setups (some lucky ones aren't even built sometimes) pop around 200whp N/A, and jesus, 15 psi of boost should make more than 100 more whp, I'd hope! Shoot me if I'm wrong. Did your built include low compression pistons? Like 4:1? What compression are you running?
Dude 12.1/1 a/f....thats way to rich, I mean kinda good since the worst thing you want with ls/vtec is a lean mixture.
But it sounds like you have to big of injectors, or to much fuel pressure, if you have injectors im not even sure, just guessing you would with a setup like that.
Id retune it, thats way to rich!
BEAUTIFUL CAR AND SETUP THOUGH NONETHELESS!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J_D_M_9_4 »</TD></TR><TR><TD CLASS="quote">what size injectors are you running, and what is your fuel pressure set to? seems a bit rich to me...retune.</TD></TR></TABLE>
i think hes trying to achieve a safe running motor oveall instead of unsafe peaky hp by leaning the **** outta it hes been through alot of headaches
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KasperFFTI »</TD></TR><TR><TD CLASS="quote">Dude 12.1/1 a/f....thats way to rich, I mean kinda good since the worst thing you want with ls/vtec is a lean mixture.
How is that way rich if it's only 12:1? Just about every tuner i've seen on this site tries to get the a/f @ 12:1.
so your final numbers are when you are running on 15lbs? If it was 11lbs then that more reasonable. I think 15lbs should neat you close to 450whp. But nice troque and horsepower. I bet that thing is a blast to drive.
