Where do these plugs of my wiring harness go?
Old Jan 8, 2004 | 08:43 PM
fcuked's Avatar
Default Where do these plugs of my wiring harness go?
I put in a '00 b16, and used my '96 cx harness, added all the necessary wires, but i have 3 problems.
Under the intake manifold i have this pos hanging off and i can't find its spot.
One more blue one?!?! WTF, i remember 4 plug plugs for the fuel injector, and another blue one with a different shape for the fuel rail piece, now i have two of the different ones, sorry bad description, but that's 6 blue plugs in total, i thought it's 5.
Last but not least, you can't see it in the pic, but there is a space to put a plug near the oil pan beside the belt, i don't think i have one on my harness that goes inside even though i clearly remember the cx motor had that plug
Old Jan 8, 2004 | 08:45 PM
Andres-eh2's Avatar
does it run? CEL's??
Old Jan 8, 2004 | 08:51 PM
fcuked's Avatar
Default Re: (Andres-eh2)
The car runs fine, vtec is working...cel is for 02.
Old Jan 9, 2004 | 03:34 AM
fcuked's Avatar
Default Re: Where do these plugs of my wiring harness go? (1.8 HB)
ttt help
Old Jan 9, 2004 | 05:31 AM
length's Avatar
Did you check the codes? often times there is more than one when your doing a swap. Crank sensor? tps ? check those....
Old Jan 9, 2004 | 06:30 AM
monicle's Avatar
the 2nd one goes to the purge solenoid %100 sure, the 1st looks alot like an ckf sensor plug, and for the 3rd im not sure.
you can see where I had to put my purge solenoid from my old car since my swap didnt come with one. its in the upper right of the picture (this is in reference to your second mystery clip)
Old Jan 9, 2004 | 06:55 AM
biggmike2's Avatar
First and Last picture are both for the Crank Senor the Middle is the Temp Sensor that hooked up to the filter box.
Oh yeah get that clip on the nipple of that fuel rail that is gas in that line and in ur picture the clip is not on
hondacurious
Nov 12, 2013 01:14 AM
woodenchef
17
Jul 14, 2013 10:09 AM
Cap'N Chronic
Apr 4, 2011 07:51 PM
ActiveAero
Dec 10, 2006 11:29 AM
GripFactoR
Nov 21, 2003 02:36 PM
