Integra 60-0 braking distance.
I'm gonna take a stab at it, and guess that it is in the 120ft range.
:edit: I found that a lightly modified suspension on the new 02 RSX-S can stop 60-0 in 118 ft. So that should give you an estimate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1995 »</TD></TR><TR><TD CLASS="quote">actually i beleive stock gsr's are closer to 150 i beleive. ITRs can do it in about 120.</TD></TR></TABLE>
150 ? what is it ? A Tahoe ? lol ANd if there was a 30 ft difference in the braking distance of the Type-R versus the other model...I bet there would be a lot more ITR 5 lug conversions
Yeah...just checked out an archived file at Honda-acura.net that claims the Type R to stop in 118ft while all other 3 dr hatch models stop around 128ft.
The 4 door GS-R is slated to stop in 142ft in there.
Here are specs on the brake systems. But braking is not all in the brakes...TIRES play a huge role as well.
ALL: Dual-diagonal, power-assisted, 4-wheel disc brakes.
LS, GS-R: Acura-designed Anti-Lock Braking System (ABS) with 4 wheel-speed sensors and electronic/hydraulic control unit. Ventilated, 10.3 in (262 mm) diameter. Solid, 9.4 in (239 mm) diameter.
Type-R: Lightweight Acura-designed Anti-Lock Braking System (ABS) with 4 wheel-speed sensors and electronic/hydraulic control unit. Ventilated, 11.1 in (282 mm) diameter, 0.98 in (25 mm) rotor thickness.Solid 10.2 in (260 mm) diameter, 0.39 in (10 mm) rotor thickness.
civic_crazy
Jul 27, 2004 10:06 PM
