88 crx hf w\jdm b16...want to swap back in a D16A6. what is there to do???
Old Jan 8, 2004 | 08:11 PM
Project_ED8's Avatar
Default 88 crx hf w\jdm b16...want to swap back in a D16A6. what is there to do???
i want so swap out my jdm b16 out of my 88 crx hf for smog purposes and put in a d16a6. what else would i need to do besides get crx axles,crx si ecu? can i use my hasport mounts and shiftlinkage? or is it only made for a b-series swap? also..i tried putting in my old crx si axle into the hub i have on the car right now but it won't fit...is this because i have integra hubs now? is there any specific way to tell if i have integra or crx si\dx hubs? cause i know you have to upgrade to either integra or crx si\dx hubs because the hf ones won't fit the integra axles. ok well thanks for any tips and advice.
Old Jan 8, 2004 | 10:34 PM
dingusjt's Avatar
Default Re: 88 crx hf w\jdm b16...want to swap back in a D16A6. what is there to do??? (Project_ED8)
1.) you need the mounts for 88-91 Civic/CRX
2.) you need axles for 88-91 Civic/CRX (you have integra axles most likely)
3.) stock si ecu if use d16a6
4.) shift linkage for 88-91 Civic/CRX
and finally you need to give me your old b16a1 swap because honestly...do you really want to just do all that work and then put the b16 back in again? and its just going to take up room in your garage anyway
Old Jan 9, 2004 | 07:06 AM
Default Re: 88 crx hf w\jdm b16...want to swap back in a D16A6. what is there to do??? (dingusjt)
haha i'm selling my b16. complete swap including motor, tranny, axles, ecu, mounts, hasport shift linkage, stage 1 clutch. all for $1700 OBO
Old Jan 9, 2004 | 09:11 AM
i know when they did the swap they had to cut and cap off pin B5(alternator pin) on the ecu so would i have to add this wire or reconnect it? where exactly does it go? they also cut pin B19 wire, would i have to reconnect this again?
B20Wannabe
Jan 10, 2012 11:08 AM
savage3006
Dec 31, 2008 05:21 PM
robbizza
Oct 17, 2006 10:53 AM
civicdust
May 2, 2005 09:11 PM
infamousR13
Mar 4, 2004 06:02 PM
