trunk leak
Old Jan 8, 2004 | 06:18 PM
lke2drvgsr's Avatar
Default trunk leak
yes i know, ive seen the team-integra articles, ive done lots of searching for this very common problem. i took out my interior panels, and my drain tubes were fine. my taillight gaskets are fine. the rubber stuff on the hatch is fine. the bottom of my backseat was soaking wet and my trunk had a little puddle in it... anyone know where else these leaks could be coming from??? thanks
Old Jan 8, 2004 | 07:31 PM
svtec's Avatar
L D E S
Default Re: trunk leak (lke2drvgsr)
the rubber sealing around the windows.
Old Jan 8, 2004 | 07:35 PM
B2FiNiTY's Avatar
Rear wiper?
Old Jan 8, 2004 | 07:56 PM
lke2drvgsr's Avatar
Default Re: trunk leak (B2FiNiTY)
rear wiper???
Old Jan 8, 2004 | 10:01 PM
PushinRedline's Avatar
attena's drain tube?
Old Jan 8, 2004 | 10:16 PM
typeR#0427's Avatar
Default Re: trunk leak (PushinRedline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PushinRedline &raquo;</TD></TR><TR><TD CLASS="quote">attena's drain tube?</TD></TR></TABLE>
Thats probably the case, I sealed mine up and the water pretty much stopped
Old Jan 8, 2004 | 10:51 PM
lke2drvgsr's Avatar
Default Re: trunk leak (hamB18C1)
wow ok, exactly how many drain tubes are there? and where are they located?
Old Jan 8, 2004 | 10:54 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If the rear seat is wet I would suspect sunroof.
Old Jan 9, 2004 | 01:07 PM
typeR#0427's Avatar
Default Re: trunk leak (PatrickGSR94)
Heres all the places that I can think of that would drain around the hatch area.
1:sunroof
2:antenna
3:taillights
4:It once appeared that I had water coming "up" into the hatch instead of draining in. I have learned to deal with that over time Theres a nice piece of ice in there when I need to cool down
Just check around for bad seals.
Old Jan 9, 2004 | 01:48 PM
Brian_TII's Avatar
Maybe check the other end of the sunroof drain tubes?
Old Jan 9, 2004 | 02:32 PM
StolenTeg's Avatar
Ummm Check your tailight see if there is moisture or water in it( Im saying this because my teg have leak problem, i check everywhere and cant find where it is) then finally i take a careful look at the tail light saw water in it. and it come out that the water was getting in from the tail light...so maybe chek that???
Old Jan 9, 2004 | 02:38 PM
evil b's Avatar
usually the drain tube, maybe it came disconnected at the top
Old Jan 10, 2004 | 11:46 AM
sunroof drain tubes can cause the problem too. there is one drain tube at each corner of the back corners, i think there's 2 in the front also but obviously the front isn't the problem
Old Jan 15, 2004 | 09:41 AM
ATSGARAGE_Jr's Avatar
Default Re: (PushinRedline)
I had the same problem , i sealed up my attenna drain tube and it went away!
thanks for the tip!
Old Jan 15, 2004 | 02:41 PM
hseriesmm
Guest
Posts: n/a
Default Re: (jdmtheory)
right on wayto go
Bignel00
May 21, 2007 10:58 AM
haroldthefly91crx
11
Jan 3, 2007 04:32 PM
GsrTurboCRX88
Dec 13, 2006 01:23 PM
NVS_RSX
25
Aug 8, 2006 06:51 PM
turbo_b18c
Nov 13, 2001 06:15 AM
