Whats wrong if your clutch is Slipping?What stage clutch do you recommend?
Okay, i recently install a turbo kit. And my clutch slip everything i put a little pressure on the gas pedal. What could be wrong? or is it alright?
And What clutch stage do you recommend using? what brand?
how many miles are on the clutch and what kind of horse power are you putting out????
right now i am running a clutch master stage 3, i love it, and it should handle my boost nicly once ready
Thanks a lot guys. Well i have a stage one (1) Clutch master, and i thought that should at least be to handle. I"m not sure what i'm making right now. Have no clue, like i said just recently install the turbo. It's a DRAG II kit. have my turbo manifold jet hot coated, a walboro fuel pump, fmu, and a Apex'i N1 exhaust sytem. it's only 2 Quater pipe. I thought they will make the 3 inch but no they don't. Don't really like custom pipe because i had once and it sound awful.
Don't for the reply, So is ACT really better than Clutch Master? What price is right for the correct clutch ? and Once again thanks very much for helping, Peace!
Hey PhazedSI, What do you mean by friction pads on the clutch disc? I don't know much but does it really mean i can't drive daily anymore? Will it at least last me another few months? please help .
Well theres friction pads on both the clutch disc and the flywheel. when the clutch is engaged these pads mate surfaces and join the engine and transmission togethor to spin at the same speed. When the clutch is disengaged the flywheel can spin freely. When the pads on the clutch disc wear the clutch begins to slip(instead of mating the flywheel and clutch spin at different speeds becuase the friction surface has wore away and now the surface is begining to become smooth). Its hard to say how long your its gonna last you w/out driving the vehicle. you will know when it starts to get really bad.
pjr710
Jul 23, 2008 09:53 AM
