still wont start
Old Jan 8, 2004 | 01:55 PM
JDMlyfestyle's Avatar
Default still wont start
Ok my car still wont start for some reason. im getting great spark and plenty of fuel why else would the car not start? car cranks over but will not start any input on this?
Old Jan 8, 2004 | 01:57 PM
redlinetuning's Avatar
Default Re: still wont start (JDMlifestyle)
have you checked your dizzy cap and rotor? check your fuses too.
Old Jan 8, 2004 | 01:59 PM
Its gettin spark all across the board. What fuses should i check?
Old Jan 8, 2004 | 02:03 PM
GTlvr82's Avatar
Sounds stupid but check your ground wires...happened to me. Car wants to start but it had a bad ground...go figure.
Old Jan 8, 2004 | 02:07 PM
Default Re: (JDMlifestyle)
check your fuses in the engine bay first.. that's where most of the critical fuses are, then check the others if there aren't any blown fuses. However, just becuase you're getting sparks doesn't necessarily mean much.. take off the dizzy cap and inspect it. if need be take some fine grain sandpaper and clean off the brushes.
have you done a diagnostics? what year and model car? pull the carpet under the pass. side dash back a ways and you'll see the ecu cover. there should be a hole with a led flashing when you turn your key to the ON position. count the flashes. If there are multiple codes, the led will flash a sequence, then pause, and the next error sequence will flash.
Old Jan 8, 2004 | 02:20 PM
-[95cxhatch]-'s Avatar
Default Re: (redlinetuning)
hey man sorry to hear about ur car check your crank sensor or cam sensor thats my 2 cents
good luck
throwing code 21 and 10. Vtec Spool Solenoid. and air intake temp sensor
Old Jan 8, 2004 | 02:35 PM
just did another code search just 10 and 21 still.
Old Jan 8, 2004 | 03:55 PM
common i need to know cause i gotta go to work in the morning..
Old Jan 8, 2004 | 04:11 PM
The vtec spool solenoid valve sensor shouldn't have anything to do with it.
take your iat sensor and put it back on. my bet's on the dizzy cap. my beater ef did the same **** to me this fall.. it was flashing all sorts of codes and i took the damn dizzy cap off and replaced the rotor.. put a new cap on, worked for a bit, then I put the old cap back on and it's been running fine since then.
Old Jan 8, 2004 | 04:14 PM
Jimmy's Avatar
Global Moderator
swap dizzy's with a friend and see if it helps.
Old Jan 8, 2004 | 04:15 PM
chad's Avatar
Moderator
check firing order....1-3-4-2
check grounds....MUST HAVE GROUND ON TRANNY ON A HONDA!!! ask me how i know....i spent countless hours trouble shooting that one!
Check to make sure crank is at TDC when cam(s) are at tdc....
other than that don't konw what else would cause it not to fire....if it has fuel and spark should crank!
Old Jan 8, 2004 | 04:21 PM
alright i will do that. keep all suggestions coming. thanks guys
Old Jan 9, 2004 | 06:16 AM
Up cause i need more info before i go diggin into the car. what fuses should i check on my car ect
Old Jan 9, 2004 | 08:31 AM
ok just checked everything once again.intake cam is advanced 5 degree's exhaust cam is O. the rotor position at top dead center is #4. does all this sound correct?
Old Jan 9, 2004 | 08:35 AM
i'm thinking rotor pos. tdc #1.. have you tried swapping dizzy caps with someone?
fuses.. just check for a blown fuse..
Old Jan 9, 2004 | 09:11 AM
dont have a spare dizzy.. checked all fuses and its all good
Old Jan 9, 2004 | 09:16 AM
just go to NAPA or Autozone and get one.. it's only like $14.. don't do Pep Boys.. their caps suck *****...
Old Jan 9, 2004 | 09:58 AM
sammysnakes's Avatar
make sure your distributor isn't 180 degrees out. take it off and rotate the shaft 180 and put it back on.
Old Jan 9, 2004 | 10:01 AM
mattssi's Avatar
I dont think they can be put in 180 off! They won't fit right! Make sure you plug wires are all correct! Check the grounds, like the one on the valve cover, and the one on the thermostat! The three main components for a running engine is spark, fuel, and timing! So If your getting 2 outta 3, check your timing!
Old Jan 9, 2004 | 10:07 AM
Default Re: (mattssi)
it can, trust me. i have done it before.
Old Jan 9, 2004 | 10:31 AM
Andres-eh2's Avatar
get a wire and put it on the
postive (+) of your starter and on the
postive (+) of the battery then try to crank.
Do you have an alarm on it? Cut off switches?
Old Jan 9, 2004 | 10:36 AM
OK the car is running. a logical thing i forgot to do i reset the ECU. then i cranked it and gave it some gas and wala. Thanks for the help guys. still cant figure out what it was that caused it to do that.
reddcoupe
Jun 12, 2012 04:48 AM
nate10498
14
Jan 18, 2009 08:56 PM
sohc90rex
16
Dec 21, 2005 09:20 PM
turbocivic0618
Nov 13, 2005 02:42 PM
BLuDoHcReX
11
Feb 5, 2003 05:32 PM
