Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Rear spring length for a 87 CRX?
Old Jan 8, 2004 | 01:26 PM
RineRacing's Avatar
Default Rear spring length for a 87 CRX?
Sorry for such the newb question but what free length spring should I run on the rear of a 87 CRX?
I read the FAQ and some posts and they all seem to point to something in the 6"-8" range.
This will be for a track only CRX on shortened Koni shocks.
Old Jan 8, 2004 | 06:53 PM
keithg's Avatar
Default Re: Rear spring length for a 87 CRX? (Geratol)
I ran a coil-over set up with 6 inch tall springs on the rear of my 1st gen SCCA GT-4 CRX. I had to fabricate an upper spring perch out of some aluminum plate with a hole in the middle of it to go where the original rear spring seated. I didn't see any other way to do it, and it worked out well.
Old Jan 9, 2004 | 08:16 AM
Adrift's Avatar
I run 6 inch 600lb ERS springs in the rear. I am using Tokico adjustables. I am exactly in the middle of the adjustment range of my OPM coilover sleeves.
Old Jan 9, 2004 | 08:34 AM
RineRacing's Avatar
Thanks for the replies. Time to go spring shopping.
Old Jan 9, 2004 | 05:36 PM
XrcR6's Avatar
Hey, hold up on the shopping. I'll give you a call later. I may have more parts to donate to the project (just need to measure the length).
Old Jan 9, 2004 | 07:12 PM
vtecvoodoo's Avatar
Future Texas Boy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Geratol &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies. Time to go spring shopping.</TD></TR></TABLE>
Just make sure you buy Eibach
Old Jan 10, 2004 | 09:56 AM
rpr's Avatar
rpr
I am using 8 inch, but I have a slightly different setup than most...
Also, i'm not using the tender spring anymore, and I have removed the lower spring perch as it should be, I don't know why I left it on there in the first place. The spring is 2.25", btw.
Old Jan 15, 2004 | 11:35 AM
RineRacing's Avatar
Default Re: (rpr)
Thanks for the visual RPR. BTW I like your web site, very hard to find GOOD 1st gen CRX info out there.
turbo-crx
Suspension & Brakes
13
Jan 23, 2009 01:09 PM
gursh d
Suspension & Brakes
Oct 22, 2007 11:34 AM
ED9man
Suspension & Brakes
Dec 7, 2006 09:23 AM
OMG WTF
20
Jul 14, 2006 03:38 AM
EFin' Kyle
Mar 26, 2006 10:00 PM
