JDM ITR Recaro SRD slider bolts
Old Jan 8, 2004 | 01:09 PM
type r 01-1063's Avatar
Default JDM ITR Recaro SRD slider bolts
I purchased a pair of SRD Recaro seats and suppositely sliders for the DC2.
When time came around for installing it, I found that the bolts for the rear middle is too short. Am I suppose to install with a longer "JDM bolt" or do I have the wrong sliders?
Old Jan 8, 2004 | 05:24 PM
Default Re: JDM ITR Recaro SRD slider bolts (type r 01-1063)
hmm...seems like nobody knows the answer to this one. (bump)
Old Jan 8, 2004 | 05:38 PM
machgo5go's Avatar
Need more clarification:
Are u describing the inner rail rear mounting point to the floor next to the
center console?
If u bought a CTR Set, the inner rails are too long and if u bolt just the front, rear hole won't line up to the floor. Outter rails by the door is ok.
Old Jan 8, 2004 | 08:07 PM
B2FiNiTY's Avatar
Got pics?
Old Jan 8, 2004 | 08:47 PM
Default Re: JDM ITR Recaro SRD slider bolts (machgo5go)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machgo5go &raquo;</TD></TR><TR><TD CLASS="quote">Need more clarification:
center console?
If u bought a CTR Set, the inner rails are too long and if u bolt just the front, rear hole won't line up to the floor. Outter rails by the door is ok.</TD></TR></TABLE>
Yes. So this means I have the wrong rails?
Old Jan 9, 2004 | 02:26 AM
machgo5go's Avatar
You got the wrong JDM Recaros from a Civic Type-R.
I got suckered first time around too so I bolted the rear of both rail first and then
forced a longer bolts into the front. The mount plate on rail with never be flush.
After a yr, I got sick of it because u actually sitting higher then normal plus when u
recline the sit forward, it hit the ceiling of the R. I sold it and search for the right one.
I end up buying a proper JDM ITR set and it bolts on in minute with no hassle and seating height is normal.
mda56
Oct 31, 2016 07:23 AM
Junaid K
Sep 4, 2014 11:09 PM
gsr-2nr
Oct 9, 2003 11:23 PM
