Type S stock exhaust diameter measured!
Old Jan 8, 2004 | 12:36 PM
sjracer's Avatar
Default Type S stock exhaust diameter measured!
After removing my HKS Hi-Power exhaust system a couple of days ago, i measured the stock RSX Type S exhaust system before i installed it back onto my car.
Here's the measurements taken with a ruler:
1) Cat Collector Flange- 2"ID
2) B-pipe Collector Flange- 2"ID
3) B-pipe- ~1 7/8"ID
4) Resonator/ B-pipe Exit Flange- 2 1/8"ID
5) Rear Section Inlet Flange- 2 1/4"ID which necks down to 2"ID
6) Rear Section Outlet- 2 1/2"ID
7) Exhaust Tip- 3 1/8"
Stock exhaust weight measured with a bathroom scale:
Rear Section- 14.5lbs
B-pipe (w/ stock donut gasket and spring bolts installed)- 13.5lbs.
__________________________________________________ _____
Total weight= 28lbs.
Just for comparison, the HKS Hi-Power exhaust weighed in at 28.5lbs total weight.
Old Jan 8, 2004 | 12:48 PM
B18CXr's Avatar
Default Re: Type S stock exhaust diameter measured! (sjracer)
just as an FYI, EP exhaust is smaller in every way
for sjracer, good info
Old Jan 8, 2004 | 01:51 PM
backyarddc5's Avatar
off topic but did u sell your exhaust yet?
Old Jan 8, 2004 | 03:05 PM
sjracer's Avatar
Default Re: Type S stock exhaust diameter measured! (backyardrsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backyardrsx &raquo;</TD></TR><TR><TD CLASS="quote">off topic but did u sell your exhaust yet?</TD></TR></TABLE>
Yup, it's sold.
B18CXr, thanks.
Edit: Would anyone care for the HKS Hi-Power specs for the Type S as well? I can post them up if anyone is interested.
Modified by sjracer at 5:04 PM 1/8/2004
Old Jan 9, 2004 | 04:48 PM
sjracer's Avatar
Default Re: Type S stock exhaust diameter measured! (racerdc5)
Can't give you any measurements because I did the install last week, so the stock exhaust is back on already, but here's the specs for the HKS:
Collector Flange- 2 1/4"ID necks down to 2"ID
B-pipe after collector flange measured to resonator entrance (B-Pipe)- 2"ID
Total B pipe (mid pipe and resonator pipe) exit flange- 2 1/4"ID
Rear section inlet- 2 1/4"ID
Rear section outlet- 2 1/4"ID
Tip- 4 5/16"ID; 4 7/16"OD
Rear Section weight- 15lbs.
B-Pipe weight- 13.5lbs.
Total weight= 28.5lbs.
Old Jan 11, 2004 | 08:08 AM
Essence of Chicken's Avatar
The EP exhaust is also heavier.
RadekSkylark
Welding / Fabrication
Dec 19, 2011 09:14 PM
contractkiller
Sep 16, 2009 10:57 PM
notAdiesel
Dec 7, 2008 10:41 PM
RSZero1
57
Nov 19, 2007 06:43 PM
stoney420
Jul 16, 2004 04:08 PM
