i really need help.
ok today has been the third day my car has been at this ****** shop for clutch installation. All i need you to do is listen to my set up and tell if it should work,
89 D16a6
90 flywheel
90 ACT clutch kit extream pressure plate with street disc
90 si tranny
The guy calls me after the third day and says theres a 100th thousandth difference between the 89 and 90 engines.
Then called DNR performance and they said it should work so i dunno, my car is down there and i gotta tell this guy somthen befor i strangle him, peace.
89 D16a6
90 flywheel
90 si tranny
The difference is in the flywheel. The 90+ are slightly larger. So, if you are using the flywheel that came with the tranny you should be set.
Go strangle the guy.
nuc79
Feb 1, 2004 08:21 PM
PaImportTuner
11
Jan 16, 2004 09:49 AM
