Preload on Sway bars
93 EG with a 22mm front sway and 22 mm ITR rear sway. Can I use regular washers to shim the pre-load on these. I plan on corner weighting before I preload the bars and afterwards. Does anyone have experience with the cross weights changing.??
https://honda-tech.com/zerothread?id=145469
There's not many topics on this, hopefully someone will have something to add
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=145469
There's not many topics on this, hopefully someone will have something to add</TD></TR></TABLE>
No kidding, not much on ALL the threads you locked too. At least not my specific question.!!
I usually find stuff when I search however my specific question is has anyone experienced any play with using the stacked washers under the end links. Does someone use anything other than washers say a urethane or hard rubber bushing to shim the sway bar for preload. I just don't want it coming loose or deflecting too much under load...and its going to get some major loads. Solo-x (Nate) any thoughts on this. I don't have your email anymore but IM me privately so I don't get locked again.
i assume you mean you are going to remove preload, correct?
at any rate, the rear swaybar is tough to change preload on since you would have to make your own adjustable endlink. (i've heard of someone selling these, don't have any info on it though) the front is easier. washers will work on the front and since they are captured on the bolt and in compression they won't slip at all. on the rear, i don't know if using a washer to space the d-bracket out will affect preload enough to be worth it.
just in case there is any confusion, the procedure that should be followed is like this:
#1 set ride height
#2 set cornerweights with swaybars disconnected
#3 align
#4 re-check cornerweights, still with swaybars disconnected
#5 re-attach swaybars, shim so no preload is on the bar
on my car it turned out that i didn't need to remove any preload from the rear bar. probably had something to do with the springrates or something. on the front i used a different length spacer between where the swaybar bushings are seperated from the lca bushings. the spacer that comes stock is about 1/4"-3/8" long. i removed it on the side that needed adjustment and put a 1/2" spacer in instead. hth
nate
#1 set ride height
#3 align
nate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x »</TD></TR><TR><TD CLASS="quote">i assume you mean you are going to remove preload, correct?
on my car it turned out that i didn't need to remove any preload from the rear bar. probably had something to do with the springrates or something. nate</TD></TR></TABLE>
Yup, sorry remove preload. I suspect i won't have to do much for either end and yes with your spring rates I doubt you'd have to do much preload adjustments to the rear. Same here although I am not going to go with quite that stiff springs as you do.
I was worried about washers (shims) moving or slipping and backing the endlink nut off. Thanks Nate. Your not going to Atlanta.?
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x »</TD></TR><TR><TD CLASS="quote">boy is .rj bustin your ***!
No ****...whatever though. All the time I was a moderator on SE-R forums for autocross and road race I NEVER had a post locked..I am 3 for 3 here. Damn I even searched before I posted like I always do...I do have alot of car tunig knowledge and an SCCA PRO SOLO title to boot but I guess its knowledge that's gonna be hard to disseminate here.
I Emailed you a while back for wheel rates and motion ratios...thanks for the info btw
nope, no atlanta for me. car is still rockin the snow tires and i only have 3 race wheels right now.
no worries about the washers causing any problems with the endlink nut. well, unless you're using several inches worth of washers. at that point i would be looking into a different tub.
nate
nate
I'm really not trying to be a pain in the ***. But one post was a WTB, the other one was on a topic that there was already a thread on, and there's so many camber and alignment threads i didnt even look at half of them before i posted links to older threads. Just try to reduce clutter thats all.
Hope this helps,
RJ
</TD></TR></TABLE>I'm really not trying to be a pain in the ***. But one post was a WTB, the other one was on a topic that there was already a thread on, and there's so many camber and alignment threads i didnt even look at half of them before i posted links to older threads. Just try to reduce clutter thats all.
Hope this helps,
RJ
clutter huh.
I disagree it was not a WTB there are 5000 places selling the A -arms and I want the cheapest closest place and the thread also invites input from those who use them. Whatever though do what you gotta do dude.
clutter huh.
If the endlink nut is still getting a lot of thread engagement, I don't think you'll have a problem with it coming loose once you've got it tightened against however many washers you need to shim the bar. You could eyeball it every once in a while to see if it's still tight or put some put some of the weaker Loctite (can't remember which color) on it if it concerns you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WRXRacer111 »</TD></TR><TR><TD CLASS="quote">If the endlink nut is still getting a lot of thread engagement, I don't think you'll have a problem with it coming loose once you've got it tightened against however many washers you need to shim the bar. You could eyeball it every once in a while to see if it's still tight or put some put some of the weaker Loctite (can't remember which color) on it if it concerns you. </TD></TR></TABLE>
Thanks Chris...too bad you aren't Atlanta bound...if my car isn't done I will be doing D Stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x »</TD></TR><TR><TD CLASS="quote">nope, no atlanta for me. car is still rockin the snow tires and i only have 3 race wheels right now.
what an excuse. If I only had a spare set of wheels I could lend you I would.
I might get around to taking out the preload on my swaybars by then. Rear should be easy but the fronts I'm not sure about.
</TD></TR></TABLE>what an excuse. If I only had a spare set of wheels I could lend you I would.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan12321 »</TD></TR><TR><TD CLASS="quote">what an excuse. If I only had a spare set of wheels I could lend you I would. </TD></TR></TABLE>
it's the first of many, trust me.
nate
nate
