Any help with adding a PCV system on a B20 bottom end.......
Old Jan 8, 2004 | 06:28 AM
whiteblurr's Avatar
Default Any help with adding a PCV system on a B20 bottom end.......
I found this fitting on http://www.z10eng.com
Description: Crankcase -12AN x 28mm Adapter For rear Breather Plugs
[ honda b-series ]
I'm wondering if this fitting could be used to replace one of the rear plugs on the back of a Crv block to add an escape route for crank case pressure..... Anyone know about this fitting?
Old Jan 8, 2004 | 11:01 AM
DavidR's Avatar
Default Re: Any help with adding a PCV system on a B20 bottom end....... (whiteblurr)
Just get the Endyn catcah system, it comes with everything you need.
boo5tedteg94
Dec 14, 2009 02:44 PM
whiteblurr
Acura TL, RL & ZDX
Jan 10, 2004 09:32 AM
crxste
Jun 18, 2003 08:47 AM
HondaGSR
Feb 19, 2003 06:32 PM
