88crx walbro in tank fuel pump in a 87 crx...
Old Jan 8, 2004 | 01:30 AM
Leperchon's Avatar
Default 88crx walbro in tank fuel pump in a 87 crx...
I just recenelty swapped a b16 into my 87 carb'd crx....but now i gotta have a fuel pump because it was carbuerated....My question is would a 88 crx walbro 255lph fuel pump fit in my 87 crx
thanks in advanced
Old Jan 8, 2004 | 01:09 PM
Leperchon's Avatar
Default Re: 88crx walbro in tank fuel pump in a 87 crx... (Leperchon)
ttt
Old Jan 8, 2004 | 04:15 PM
Leperchon's Avatar
Come on someone has to know
Old Jan 8, 2004 | 05:11 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
I put a Corvette fuel pump in a S-10 if that helps..
If you hook up the wires and rig it in, it will pump..
Did your car have a pump in the tank already or not?
If not,you need some stuff off of a fuel injected model..
Fuel injection also requires a return line to the tank which a carbed
model might not have had.. Sorry,I am a mechanic but I am not as familiar with
the earlier models..
This site might help but turn on your pop up blocker first: http://coreyonline.tripod.com/crxmainpage.html
Old Jan 8, 2004 | 06:28 PM
seekerONE's Avatar
84-87 crx used fuel pump NOT in the tank(carbed cars were mechanical while si models used a electric pump located in the left rear wheel area.)
So to answer your question...no an intank pump won't work...unless you are ready to do a certain amount of fabrication on your fuel tank
hmonkey86
Feb 7, 2012 05:02 AM
maddcrx
May 9, 2008 07:29 PM
dsettlemoir
Mar 25, 2008 11:32 AM
