EF newbie, EG grandparent (rear disc swap questions)
Old Jan 7, 2004 | 11:30 PM
snowboarderguy44's Avatar
Default EF newbie, EG grandparent (rear disc swap questions)
im picking up a very decent conditioned CRX soon, and i want to swap the rear drums to discs. I have an EG rear trailing-arm set w/discs. will this bolt up to the CRX rear suspension linkage, for that matter, will the del sol prop valve work too??
Old Jan 8, 2004 | 03:28 PM
mad2nr's Avatar
Default Re: EF newbie, EG grandparent (snowboarderguy44)
i dont believe so. worth the try tho. if not definately 90-93 integ lca's. easy swap and looks sharp as **** on a rex with nice wheels.
Old Jan 8, 2004 | 03:33 PM
bryant's Avatar
Rear disc will work . Just make sure to use 90-91 CRX Si ebrake cables. (BTW I have some FS ) or you probley could use your EG ebrake cables and they should work just fine. Prop valve, I dont know.
Old Jan 8, 2004 | 03:56 PM
EL Vap133's Avatar
Default Re: EF newbie, EG grandparent (Bryant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant &raquo;</TD></TR><TR><TD CLASS="quote">Rear disc will work . Just make sure to use 90-91 CRX Si ebrake cables. (BTW I have some FS ) or you probley could use your EG ebrake cables and they should work just fine. Prop valve, I dont know.</TD></TR></TABLE>
It will work, use your stock LCAs and stock struts. Use 90-91 crx si e-brake cables for a direct fit and I am not sure if you can use a Del Sol prop valve so I would suggest you use a 90-91 crx si prop valve instead...
jacksonww
Feb 7, 2011 11:09 AM
got_no_sol
Nov 18, 2009 08:57 AM
CO_CReX
Nov 16, 2006 08:12 PM
silver_flash99
Oct 19, 2005 11:37 AM
Blitzed
Feb 8, 2004 12:07 PM
