91 LS swap into 94 civic ex
Old Jan 7, 2004 | 08:34 PM
94LSCIVIC's Avatar
Default 91 LS swap into 94 civic ex
putting 91 ls motor in 94 civic ex need to know what is all involed in it? as far as motor mounts, shift linkage, and wiring? need some help??? have done a b16a1 swap into 92 hatch
Old Jan 7, 2004 | 08:45 PM
CRXLST's Avatar
Default Re: 91 LS swap into 94 civic ex (94LSCIVIC)
U will need mounts, shift linkage, and axles.... U can use the same ECU but I would reccommend a LS ecu... I m not sure if U can use the same wiring harness.. U could to get it 2 run vut all the sensors might not hookup
Old Jan 8, 2004 | 12:53 AM
FURACERMAN's Avatar
It's OBD0
Old Jan 8, 2004 | 09:07 AM
rca90gsx's Avatar
Default Re: 91 LS swap into 94 civic ex (CRXLST)
I believe this car is going to be mainly only using the LS bottom end, its going to be using a newer B series Hydro tranny (b16a) I believe....think he's mainly concerned with installing the 91 LS bottom end, with a newer ( b16a) trans....
my91ls4dr
May 22, 2008 07:37 AM
abusedvtec
Mar 27, 2008 05:51 PM
KiLlInG 562
10
Aug 13, 2005 12:39 PM
ITR.#1446
Feb 6, 2005 09:27 PM
EF9 JAMS!!!
Sep 28, 2004 04:57 PM
