Grounds. OverKill? Location?
Old Jan 7, 2004 | 07:46 PM
another_crx's Avatar
Default Grounds. OverKill? Location?
Im swapping in a sohc zc into my crx and am also doing a pretty large dual 1000 watt amp system + a few other high power drawing items. Would it hurt to use 4ga wire on all 3 grounds on my ef? Like it doesnt hurt it right? I have a lot left over and just want to make use of it. Thought this would be a good time
Also does anyone have a diagram on where all the grounds are on a sohc zc? Only one Ive ever really seen and noticed was the one from the valve cover
Thanks
Old Jan 7, 2004 | 08:51 PM
Donkey85's Avatar
Default Re: Grounds. OverKill? Location? (another_crx)
no it wouldn't hurt anything. if anything it would only help think of the jdm wiring kits same idea
Old Jan 8, 2004 | 03:02 AM
FourthGenHatch's Avatar
There are 3 stock grounds...
Valve Cover > Chassis
Neg Bat Post > Chassis > Tranny
Wiring Harness > Thermostat
You can't really replace the thermostat ground since it is inside a wiring harness, I wouldn't touch it.
Old Jan 8, 2004 | 06:44 AM
Ef Whore's Avatar
Default Re: Grounds. OverKill? Location? (FourthGenHatch)
I upgraded my grounds in my prelude to 8 AWG with brass ends. I noticed more solid starts and my dash lights seemed brighter at night. In any case it really can't hurt to upgrade from those old stock grounds.
Old Jan 8, 2004 | 07:09 AM
kid-honda's Avatar
That is something I always do when I buy a new car.
Its a good cheap improvment so why not do it.
billy_thekid
Sep 26, 2007 04:54 PM
Tippyman
Apr 11, 2006 08:34 PM
mikezcdx
Mar 9, 2006 07:16 AM
