CKF on JDM B18c......
Old Jan 7, 2004 | 05:22 PM
Team 4R's Avatar
Default CKF on JDM B18c......
where the hell is it...?! i'm trying to wire up this b18c with a 2000 si wiring harness and the only plug i have left is, according to my haynes repair manual, the crankshaft fluctuation sensor (ckf).... also according to my repair manual the ckf is located next to the crankshaft pulley.... does that mean behind the timing belt cover? i already changed the timing belt and closed up the covers and pulley but i don't remember even seeing an electrical connector back there.... so where is it? or do i not have one? any help is appreciated. thanks in advance.
Old Jan 8, 2004 | 11:57 AM
iiilgsrlll's Avatar
Default Re: CKF on JDM B18c...... (Team 4R)
Is the motor OBD1 or OBD2?
It only exists on the OBD2 motors on the B18C1. I believe it monitors the crank speed for misfires.
Old Jan 8, 2004 | 01:18 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
OBD2 J-spec B18C (ITR) does NOT have a crank flux sensor. It also only has one O2 sensor. You also have to use a J-spec ECU if you are using the J-spec VTEC solenoid, or you have to use a USDM VTEC solenoid if you are using a USDM ECU.
tweatybird74
May 14, 2010 08:50 PM
datflyboy
Jun 10, 2009 08:20 PM
roc
Mar 26, 2009 02:28 PM
speedymon
Apr 25, 2003 10:43 PM
