ys1 with Quaife or b16 s1 w/ lsd and ls 5th
Old Jan 7, 2004 | 05:10 PM
Neukin's Avatar
Default ys1 with Quaife or b16 s1 w/ lsd and ls 5th
so i have a jdm s1 tranny (LSD) and i can just toss a LS 5th on there? i have a 300hp(400-500 later) turbo crx and boost hits at about 4800rpm 1 , 2 and 3 sometimes rip loose. no traction in 1 and 2. i top out at 130 and i shift too much. highway sucks.
sooooo what should i go with s1 with LS 5th or just a LS tranny 90-93 ys1 with Quaife? with that much hp the LS seems it would be better. iv also got a grind in 3rd (can i even get sycros for the jdm s1 i heard parts are hard to find with this tranny) so thats my situation assess my friends
the ys1 from integra is goginto top out at what 145mph?
Old Jan 8, 2004 | 03:53 AM
Neukin's Avatar
Default Re: ys1 with Quaife or b16 s1 w/ lsd and ls 5th (toyosupr)
somebody please waste one min. and tell me what you would do.
Old Jan 8, 2004 | 06:28 AM
whiteblurr's Avatar
The only problem I have heard with swapping in the LS 5th is when you are shifting from 4th into 5th, you will bog the car down slightly. It comes down to driver preference. If you can live with that then do it.
BTW, I have a YS1 w/ quaife........ Crusing in 5th at 4K on the highway sucks
Old Jan 8, 2004 | 07:14 AM
jdmlsvtecrx's Avatar
well,,, i had that in my rex with ls/vtec,, the difference between 4th and 5th is huge,, and it kill any and all performance.....also when with that big of a difference the syncro has to do alot more work,, making 5th gear grind pretty fast.. i wouldnt do it... also,, as far as i know the 3,4,5 gear syncro out of a d series tranny will work,, or at least they are the same size,, so if yer gonna go straight,, ls,, fix the s1, and sell it...
Old Jan 8, 2004 | 07:32 AM
mmuller's Avatar
Mad Scientist
Default Re: (jdmlsvtecrx)
with 300 hp it wont make much of a difference in bogging the car and such.
I would just get an ls tranny, with that much hp it would benefit you to have longer gears.
Old Jan 8, 2004 | 11:16 AM
Neukin's Avatar
Default Re: ys1 with Quaife or b16 s1 w/ lsd and ls 5th (whiteblurr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteblurr &raquo;</TD></TR><TR><TD CLASS="quote">
BTW, I have a YS1 w/ quaife........ Crusing in 5th at 4K on the highway sucks </TD></TR></TABLE>
the ys1 is a LS right??? and how does that suck 5th @ 4k thats what i want.
i cruse in 5th almost in vtec... 5600 or so
thanks for the info guys
Old Jan 8, 2004 | 11:27 AM
turboxsi's Avatar
im pretty sure the YS1 is the 92-93 gsr cable tranny (its one of honda's shortest geared cable trannies made). I have that tranny in my 93 gsr.
Do a search for YS1, and you will get alot of answers/opinions about the YS1
Old Jan 8, 2004 | 11:39 AM
mmuller's Avatar
Mad Scientist
Default Re: ys1 with Quaife or b16 s1 w/ lsd and ls 5th (turboxsi)
yeah, ys1 is from 92-93 gsr.SHORT gears
Old Jan 8, 2004 | 02:54 PM
acy76's Avatar
YS1 code can be either LS or GSR. Mine was from an LS, as are probably most YS1s. No way to tell gearing from the outside that I know of.
Old Jan 8, 2004 | 06:03 PM
Neukin's Avatar
Default Re: ys1 with Quaife or b16 s1 w/ lsd and ls 5th (acy76)
alright. are the LS "ys1" parts avaible if rebuild is needed. unlike the s1 i have parts are hard to find i guess
Old Jan 8, 2004 | 06:55 PM
untitled's Avatar
yes, at the dealership...
Old Jan 8, 2004 | 07:06 PM
Neukin's Avatar
Default Re: ys1 with Quaife or b16 s1 w/ lsd and ls 5th (Vetter)
is that what everyone else uses just stock... anything better out there.
Old Jan 8, 2004 | 07:32 PM
acy76's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyosupr &raquo;</TD></TR><TR><TD CLASS="quote">alright. are the LS "ys1" parts avaible if rebuild is needed. unlike the s1 i have parts are hard to find i guess</TD></TR></TABLE>
many (almost all) of the YS1 parts also interchange with the newer hydro trans parts, so parts availibility isn't really an issue.
jspeceg
Nov 13, 2009 06:22 AM
b18tegg
Nov 27, 2007 07:12 PM
crowder13
Oct 8, 2007 10:57 PM
Boostage
Nov 22, 2003 07:19 PM
paulzy
Aug 13, 2003 02:51 AM
